Rear rose joint help on my S3
S3_nick Jan 26, 2014
  1. S3_nick
    S3_nick Member
    90
    Got my S3 stripped at the moment doing a major rebuild and the rose joints that is pressed into the hub that the tie bar mounts to has popped out of its mounting so needs replacing not a issue but I read somewhere you can replace these with a poly bush dose anyone know if this is true? If so what and where can I get these from?
    Thanks in advanced :)
  2. coolspot007007
    coolspot007007 Member
    40
    I've not seen a poly one, but the rose joint is superceeded by a conventional bush now as they seize eventually, causing strain on the tie arms, making them snap.
  3. mark_S3
    mark_S3 Team Silver
    790
    294
    http://www.audi-sport.net/vb/showthread.php?t=205909
    Hope this helps.
    One of my rose joints failed on me recently causing my upper arm to crack.
    Replaced two of of the four using a home made contraption of a high tensile threaded bar and sockets.
    Got daveS3 adjustable control arms to go on shortly. ;-)
  4. coolspot007007
    40
    Do you remember the socket sizes required? I'm planning on swapping to the revised bush myself as I have creaking but couldn't see signs of cracks (yet).
  5. mark_S3
    mark_S3 Team Silver
    790
    294
    IIRC..... 32mm on the bush, then 46mm on other side of hub.
    Did the job perfectly.
  6. mark_S3
    mark_S3 Team Silver
    790
    294
    There's the contraption in action ;-)
    The Doctor and s3dave like this.
  7. Kyle_TT
    Kyle_TT New Member
