Rear Park Sensor Holes - Different Sizes
Sarah's A3 May 17, 2010
  1. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Moderator
    5,920
    30
    Just realised that the rear bumper I now have to add when doing the front conversion has 18mm park sensor holes! The holes in my current bumper are 25mm, slightly larger. Do you know when they changed them to the smaller size and wheres the best place to pick some 18mm sensors up as ebay never seems to have the 18mm ones!
    thanks in advance and i'm slowly getting bits together!!!
  2. Ash187
    7,524
    759
    from what i know there are only the 2 different size sensors, as i just managed to source the larger sensors for my replacement S-Line bumper. I know a guy who might be able to help you with the sensors if you need them as he said he has both size sensors for sale.
  3. Sarah's A3
    5,920
    30
    Yes please if you can PM me his details, ta!
  4. auroan
    auroan Active Member
    1,669
    I think the larger holes are dealer fit sensors and the smaller holes are factory fit.
  5. Ash187
    7,524
    759
    as far as i know the larger ones were the old sensors fitted in cars upto 56 plate when the smaller sensors came in on 56/07 cars.
    i have a 56plate s-line rear bumper that has the larger sensors.
  6. Lee_R
    Lee_R Active Member
    2,499
    12
    They are big on the older style bumpers, the 06 onwards cars have a smaller one, probably due to the bumper being smooth and the bigger ones look a bit obvious.
    Its easy to spot the difference, the old big ones have a circular trim round them and the new ones and just a falt circle.
  7. Khufu
    Khufu Well-Known Member
    5,704
    31
    As Lee says, they were able to make them smaller so less noticable. The may also also mate up with a different loom/PDC unit too.
  8. Sarah's A3
    5,920
    30
    So if I 'm able to get t set of the smaller sensors they should just plug in my wiring thats already there? Or will I need new wiring too??
    thanks for all replies already!
  9. Ash187
    7,524
    759
    from what i heard the wires are the same, as are the modules. but you can confirm with others here
  10. scott b
    scott b Active Member VCDS Map User
    1,254
    if you get genuin audi ones they should just plug in, i can get small sensors, there made by a company called laserline, but they wont plug and play
  11. Lee_R
    Lee_R Active Member
    2,499
    12
    Yeah i'm sure they just plug in but I think they are something stupid like £80 each from Audi
  12. Ash187
    7,524
    759
    the guy i bought my sensors from sold 4 perfect fit sensors for £40 (£10 each)
    he also has the wires to connect from the sensor to the module for £10
    i'm sure he said he had the smaller sensors and would do it for the same price
  13. Pii
    Pii Member
    748
    Wasn't there a thread here a while back about rear parking sensors?
    I think there was mention that that the larger ones were the old style and are are now predominantly used on aftermarkets.... There was a lot of good information in that thread but I can't remember much of it; memory is like a goldfish...
  14. mattandrew
    mattandrew Member
    977
    21
    Just to clarify a few things the newer style bumpers do use a smaller sensor which have a different size plug on them so are not compatible with your plugs. you would need to buy 4 new plugs and a load or repair wires and rewire each of the pins. You could also buy a new loom BUT the wriring in the new loom is different so extra wiring would still be needed.
    The best solution would be to drill out the holes and fit the old sensors, on the back of the old bumper there is a plastic bracket which is double-sided sticky tapped on, this needs transfering to the new bumper. Easy enough to do, I did it on a mates A3
  15. thejolster
    thejolster Member Team Daytona Audi S3 saloon
    71
    10
    What size drill did you use to drill the holes out bigger as I was planning on swapping my bumper this weekend until I saw the thread about different size parking sensor holes. This method does seem the easier way of going about it instead of buying new plugs and rewire.
  16. jameo84
    jameo84 Member
    122
