Rear number plate lights
charlie_kerr Mar 7, 2010
  1. charlie_kerr
    charlie_kerr New Member
    24
    Help please, bought a set of LED bulbs from ebay, went to fit them and they did not work, fitted the originals and now they don't work, DIS error now showing, and cannot find a specific fuse. Has anyone else had the same problem?
  2. Cockney Boy
    Cockney Boy Member
    483
    Turn the ignition off for about 30 minutes and see if the fault goes away, if it does not then, you will need to clear the fault codes with VCDS
  3. charlie_kerr
    24
    Cheers CB, been off all night and still not cleared, I'm more worried at getting the lights working again, is it as simple as new bulbs?
  4. Cockney Boy
    Cockney Boy Member
    483
    If your old bulbs worked, then fitting new ones wont make any difference. Chances are you need to have all the fault codes cleared which should sort out all the issues
  5. The Slug
    The Slug Active Member
    1,869
    clear codes or diconnect battery for a quick solution
  6. JimC64
    JimC64 Active Member
    246
    29
    Hey there Charlie, don't know about your specific problem except that I fitted LED bulbs to the number plates and they wouldn't work without fitting a resistor. Kept on getting the DIS error showing. I fitted the rersistors and they've been working fine for around 6 months at least I'd say. They look top notch and give off a really bright white bluish tinge to the rear of the vehicle.
    Please see my thread below
    http://www.vwaudiforum.co.uk/forum/showthread.php?t=68951
    Hope it helps some
    Jim
