Rear light keeps blowing,
heap1000 Dec 18, 2012
  1. heap1000
    heap1000 Member
    158
    The passengers side rear light blew last week so i changed it on saturday. I have just noticed that it is out again!
    I know it is possible for light bulbs to blow at any time but us there a chance i have something wrong somewhere? If so what coukd this be?
  2. Jay.Ing
    Jay.Ing Active Member Team Ibis Bronze Supporter Audi A3 Black Edition TDi
    306
    I know its a silly question but... did you replace it with the right rated bulb?
    Or Get a voltmeter on it to see how much voltage it is kicking out!
  3. J8TT X
    J8TT X Member
    360
    9
    What make of bulb did you use?
    I had that problem when I replaced them with some cheap Halfords ones. then I spent a little extra on some quality ones, replaced both sides and its been fine since.
  4. _G_
    _G_ Active Member
    875
    35
    This happened twice to me and third time lucky. I think it was down to oil spots on the bulb. If you change a bulb with oily fingers then it can shorten the life of the bulb. Third time I changed it with gloves and no problems since.. or it could just be that it was a bad bulb. Change it again and see how you go.
  5. heap1000
    heap1000 Member
    158
    Bulbs are 12v 10w £3.99 for 2 from halfords. Just changed it again and the old bulb did not look like it had blown? Put the new ine it and turned the lights on and it was still out?turned the engine on and checked again and jt was on! Tried again with the engine off and it was on.will see what happens now.
  6. kev1000
    kev1000 Member
    209
    mine were blowing a lot and it turned out to be the bulb holder
  7. mike foster
    3,967
    That's because the control module switches the circuit off when the bulb blows. You have to switch the ignition on to re-set the circuit after you have replaced the bulb.
    It should be ok now.
  8. StewMang
    StewMang Member
    32
    I had exactly the same problem. Driver's side brake bulb replaced with a cheap halfords one and it blew again within a week. I'm always very careful not to touch the glass with my fingers so don't think this was the problem. Replaced it again with a more expensive bulb and it's been fine since.
  9. mookster
    mookster Active Member quattro
    271
    72
    Clever stuff :sm4:
    kev1000 > what was the issue with the bulb holder, dodgy earth somewhere?
  10. heap1000
    heap1000 Member
    158
    Ok set off to work this morning and the light was on Got to work and checked and it was out. I turnes the engine off and on again and the light came back on! So i am guessing it is not the bulb?
  11. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Corrosion / poor connection somewhere...
  12. heap1000
    heap1000 Member
    158
    Is it just a case of taking the connecting wire off and cleaning the metal bits?
  13. _G_
    _G_ Active Member
    875
    35
    yeh use some contact cleaner... you can get it from halfords or maplin..
    be careful not to use a massive metal brush like i once did... it caused a spark and mini flame.. so be delicate with the an ear bud or something.. give that a go.. spray the solution and clean it gently or spray/dip the bud and the use it to clean.
    heap1000 likes this.
  14. kev1000
    kev1000 Member
    209
    it was mostly my driver side indicator that was blowing a lot.
    also my brake light didn't work some times even though the bulb was ok.
    I bought a used bulb holder on ebay for £14 and I've had no problems since.
    not sure why but I think a lot of holders give trouble after a while.
    Here is the holder I replaced
  15. Sheikh
    Sheikh Member
    654
    20
    I had this same problem on my A3 just before I sold it, I got so fed up of changing bulbs I took the car to the main dealer who told me the a rubber seal that sits around the light was missing? And thus water was getting in and blowing the bulbs.
    Sold the car the day after so can't really comment on a fix. Sorry.
