Rear light intermittant fault
Geoffsprite Aug 9, 2013
  1. Geoffsprite
    Geoffsprite New Member
    My 2008 TT has developed a fault (on the outside of the two) off side rear light , it will come on for about 10 secs and then go out. I have just changed the bulb and the same thing is happening again. Any Thoughts? The inside bulb of the two is working perfectly.
    Thanks for any info.
  2. hades-
    9,481
    646
    did you check the bulb holder for corosion ?
    give it a clean up with wire wool
  3. Geoffsprite
    Thanks Bez for that, I will certainly try that in the Morning
