Rear Light Cluster
Nitro Mar 22, 2010
  1. Nitro
    Nitro Member
    183
    I have a crack in the offside (drivers side) rear light cluster, Have the new unit now. Does anyone know how to change these it looks quite strange design
  2. Oranoco
    Oranoco Well-Known Member
    3,862
    381
    Remove the inner carpet or access panel cover. Remove bulb holder. Undo 4 8mm nuts (iirc) remove unit carefully releasing safety retaining clips. Should be able to do it in less than 20 minutes including a cuppa. If your new lense doesn't have the foam seal you will need to swap it over from your old unit. As Mr Haynes says "Refitment is the reverse of removal"
