Rear lamp removal guide
ilim Sep 13, 2012
  1. ilim
    ilim Active Member
    665
    41
    I need to replace the rear lamp due to a "stone" crack I have the replacement but dnt know how to get the old on out, anyone got a guide or info about this?
    Ilim
  2. jimpa10
    jimpa10 Member
    64
  3. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,760
    354
    There's 2 little plastic discs that hide two bolts, then you just gently prise the light off from the outside (carefully, so you don't damage the wire). Unplug the plastic connector and then reverse the process for fitting the new one. It's a 5min job, really easy. There was even a screw driver with the right hex fitting in with my spare wheel for undoing the 2 bolts.
  4. Lewis583
    956
    91
    Carefull with the 2 plastic covers, they can fall inside the panel never to be seen again. Ask me how i know this
  5. icekay
    icekay Member
    79
    Ditto happened to me too
  6. ilim
    ilim Active Member
    665
    41
    Love the video. Mother ****eeeerrrrrrrrr hahaha
  7. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    That video is a classic
  8. sachen
    sachen Member
    246
    Awesome video! It sounds like he is high whilst hes teaching us all!
  9. ilim
    ilim Active Member
    665
    41
    How do u change this lamp. There is only one screw that holds the passenger side help...
  10. ilim
    ilim Active Member
    665
    41
    Done now, nazi inventions
  11. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,509
    412
    Haha, 'nazi inventions'. Glad to hear you got it sorted too, even if you did have to buy the new light yourself. :keule:
  12. M320au
    M320au New Member
    10
    Did this today, thanks for the tips. My rear right reversing globe is not working - although no warnings shown on the dash. Left works fine. Went to Audi and got a replacement globe this morning - but after removing tail light it looked completely different to the one that came out and wouldn't fit in the socket. The faulty one appeared to be a long thin type that sat in some kind of adaptor to make it fit in the holder - Yet the new one was a completely different shape and had no metal base - just a glass globe with tiny metal prongs visible at the base. It wouldn't fit in with, or without, the adaptor.
    To make things even more confusing, i then Pulled apart my left (working) rear lamp to see what was globe was In there - it was different yet again to both the new part supplied by Audi as well as the faulty one on the right hand side. The working globe was exactly the same as the stop light globe in the same assembly however. Again, the Audi supplied globe wouldn't fit.
    So, I took the working globe and put it in my faulty right side - surely that should give some sign of life. It fit, but didn't illuminate. Instead I got a dash warning telling me my rear left light lights were faulty (obviously because I had removed a globe). Put the same globe back in the left again, warning cleared, left light works again.
    Im confused as hell. 3 different globes types and none of them working on one side, even when i put a known working one in from the pther side. Can someone post a pic of what the correct globe should look like, and confirm that indeed both reversing globes are meant to illuminate when car placed in reverse gear? I recently bought the car - so - Is it possible the PO has used a Vagcom tool to de-activate one rear right reversing globe and eliminate it from producing a dash warning?
    Any help appreciated. 2004 a3 8p 3 door.
    Edited to add image of each globe:
    m320
  13. Daggerit
    1,509
    412
    This might sound stupid but I'm pretty sure that when I had my A3 only one side actually activated when in reverse anyway? I thought that the other side was the fog light?
  14. Lewis583
    956
    91
    Near side is reverse light. Offside is fog lamp
  15. mike foster
    3,967
    That's right ! On the 3 door the offside equivalent to the reversing light is the rear fog light that can only operate when the headlights have been switched on. You pull the switch out towards you to activate.
    Nearside is the reversing light.
    On the sportback both sides are identical.
  16. Daggerit
    1,509
    412
    So basically unless you have no reversing light at all, M320au, then your lights are functioning correctly. :)
  17. M320au
    M320au New Member
    10
    Ahh, that must explain it, thank you. :) I do have fog lights installed, so will give them a try tomorrow and see if that brings the mystery light on!
  18. Daggerit
    1,509
    412
    Pleasure mate, makes life a bit less stressful for you hopefully! ;)
  19. thebambam
    thebambam P.I.M.P
    65
    Yeah you only have 1 reverse 1 fog , I moved to germany obviously had to change them and was confused when audi give me the wrong bulb. You can switch over the wiring if you get new light units. Not to hard 15 min jobby.
  20. M320au
    M320au New Member
    10
    I was unsure after three different pieces of information:
    a) The guy doing the MOT (australian equivalent anyway) informed me European cars only had 1 reverse light so I had no problems, then
    b) a friend put his A4 into reverse gear and I saw two reverse lights come on, proving the above wrong, then
    c) when I asked Audi if I should have 1 or 2 reversing lights, he said "computer says you should have two for your car".
    What I didn't make clear to Audi however was that I have a 3dr, not a sportback - hence there's an answer in here somewhere. Will put the old globe + adaptor in tomorrow and see if it lights - with and without fog lights. I suspect it might.
    Thanks for your help -
    m
  21. thebambam
    thebambam P.I.M.P
    65
    I Have the a3 3 door version. 1 fog. 1 reverse.
  22. MJR
    MJR Member
    61
    10
    I have a 5 door A3 Sports-back (2005), im in the proccess of trying to change the reverse light bulbs for Cree LED bulbs, both lights look like they have reverse lights, however only one seems to work, im not sure if a bulb is out or if one of the bulbs is a reverse bulb and the other is a fog, it might make it easier if i could actually get the bulbs out but the method has alluded me, in other words i dont no what im doing, lol can someone let me know how i gain access to the bulbs please, i had a go earlier but couldnt gain access, i took the plastic cap off and i unplugged the wire but i couldnt get the plastic housing unit out which holds the bulbs, sorry for the novice Q this is my first A3, help would be appreciated, thanks!
