rear interior light not working? avant version
Lee_R Apr 13, 2014
  1. Lee_R
    Lee_R Active Member
    2,499
    12
    My 04 avant has a problem with the rear interior light not working. The one in the roof above the boot space. The front and middle lights work fine, so does the tailgate one.
    Nothing on vcds, fuse ok, bulbs changed for new. Still nothing! Any ideas?
  2. quattrojames
    14,050
    575
    Micro switch in the handle or broken wire at the hinge point?
  3. Lee_R
    Lee_R Active Member
    2,499
    12
    I've seen the microswitch mentioned but it doesn't manually turn on either so not sure its got anything to do with the opening or closing
  4. cobraBLACK
    cobraBLACK Chocolate? It's doo-doo, baby!
    366
    19
    Did you get anywhere with this? I have the same problem but I can't see how to remove the lamp unit to check the wiring.
  5. deano1978
    deano1978 different gear
    713
    81
    I had this too,there are clips holding it in. I just replaced mine and works fine again.
    £10 breakers,b7 fits too.
  6. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Yeh I have intermittent lighting. Works fine then nothing for weeks,proper annoying,goin have a look in min see if I can solve it,will let you know.
  7. ruffrida
    1,926
    313
    Yep mine is broken,it is the unit itself,when push on certain places it comes back on for a few seconds, new unit it is then
  8. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,196
    160
    Our a6 was doing this. There was a broken solder joint. Quick fix.
  9. cobraBLACK
    366
    19
    Just after posting I noticed the bulbs illuminated if I touched them against the contacts but not if they were seated properly, even though it was all clean. I pushed the central area (where the switch is located) upwards, there was a click and now they work again.
