Rear end knocking
rizzini7 Feb 15, 2012
  1. rizzini7
    rizzini7 Active Member VCDS Map User
    983
    156
    43
    A week after lowering my Avant (30mm with b5 spring cups) im now getting a knock/lump on the rear when the passenger rear wheel (sounds like its coming from here) catches a pot hole. Doesnt always seem to do it and only on back roads. Have been and had 4 wheel alignment and they couldnt see anything wrong. The noise sounds like the boot isnt shut properly if you know what i mean. Any ideas???
    Probably not related at all but i also had new brakes, fitted new alloys and tyres A6 Slines Et43 with 235/40/18 and a full service including fuel filter at the same time just to give as much info as i can.
  2. maddrick92
    maddrick92 Member
    97
    13
    I have same problem im getting my car on a lift tomorrow so if i find out ill let you know ;-)
  3. rizzini7
    983
    156
    43
    Thanks, hopefully its nothing much
  4. Burt25
    Burt25 Member
    54
    I had a similar noise on mine, turned out to be a broken spring - pop both rear wheels off and check the base of the spring - mine had broken off and the broken piece was knocking about causing the noise
  5. maddrick92
    maddrick92 Member
    97
    13
    Didnt have chance at looking at the noise today due to my bss lms getting fitted but on my next day off ill have a look
  6. infernalzen
    infernalzen New Member
    29
    the wheel hitting the arch liner, or the bump stop being hit :(
    usualy the bump stop neds shortening too
  7. rizzini7
    983
    156
    43
    Will be getting mine looked at Monday night again. Will update if i find anything
  8. maddrick92
    maddrick92 Member
    97
    13
    Thats a very good shout mate was think of doing that.... Theyw ill just cut down wount they ?
  9. rizzini7
    983
    156
    43
    Well, hoping to have a look tomorrow night.Few other clunks but i assume thats just the result of new stiffer springs.
  10. rizzini7
    983
    156
    43
    Well, turns out my knocking is from the Rs4 RARB. The bushes have started to slip off???? Mymate thinks they may be a bit soft. So gonna order some poly ones and see how it goes
  11. maddrick92
    maddrick92 Member
    97
    13
    Cool i sorted mine out today all mine was was the adhustable cup on the rear was rattling about so at work i make a a clamp as such and fitted it.... Outcome = mint, im so happy iv sorted it now.
    Also managed to fit my new cupra r splitter as my old one was smashed to hell due to me not fitting it right last time so had a sucessful day today and really happy with the outcome :)
  12. rizzini7
    983
    156
    43
    Good news, just need to sort my xenon and front end judder
