rear door speakers
rasA4 Feb 22, 2007
  1. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    hi i have a face lift A4 saloon with symphony HU just wanted know if the rear doors are pre-wired for speakers?
    thanks
  2. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,415
    2,979
    Hi, Ras. Long time, no speak. B5 A4 saloon has no wiring to rear doors for speakers. I wanted to install rear door speakers on my old 2.8Q but no joy.
    Take care, old buddy.
  3. rasA4
    3,287
    119
    cheers Jeff
    ill have to work out a way to wire them in hopefully i dont have to run them all they way from the HU? i have the speakers already on some new door cards.
  4. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Audi HU can't drive rear speakers. It only has an internal amp for the fronts. You'll need to either take a feed from the rears in the back shelf or install a small amp to drive them.
  5. rasA4
    3,287
    119
    Cheers Andy do i just tee in L & R speaker connections?
  6. rasA4
    3,287
    119
    Andy also im looking for a sub amp that i can control the loudness from the from like a knob or something so when children in the car i can turn it down.
  7. AndyMac
    9,832
    46
    Have a look for one with a wireless remote control, otherwise you're looking at quite a bit of rewiring
  8. rasA4
    3,287
    119
    any particular makes or models its a mine field out there?
    im also thinking would the rear EXISTING amp be ok if i connect the rear door speakers to this>?
    thanks again
  9. AndyMac
    9,832
    46
    No definately not. It's only 2 x 20w and the size of a matchbox, you'd need to hook up the door speakers in series with the rear deck speakers otherwise you'll be halving the impedance which will kill the stock amp.
    If you're installing a sub I'd disconnect the rear deck speakers and just rewire the amp to the rear doors. The deck speakers sound awful and will sound even worse with a sub thumping up behind them.
    I'm sure I saw some amps that had wireless remotes, but can't see any on the net now. There are a few with wired bass controllers, this Kenwood is a bargain at £120 for 500wrms bridged.
    http://caraudiosecurity.com/shop/product/products_id/3569.html
  10. rasA4
    3,287
    119
    wow that amps a beast 280mm x 286mm can i mount this to the parcel shelf underside with the help of mdf?
