Rear Door quick question
cjrob Mar 16, 2010
  1. cjrob
    cjrob Member
    44
    I am about to replace a rear door as mine has been keyed by some local scroats!!
    its is a prefacelift 1998 A4 Avant and I have seen this door on ebay
    http://cgi.ebay.co.uk/1998-AUDI-A4-...arts_Vehicles_CarParts_SM?hash=item5ad7f485bb
    now it says its a 98 but states its off a facelift and I am not sure if the pre-face lift and post have different door styles (I am thinking it may just be the bump strips)
    can anybody confirm?
  2. jcb
    jcb Active Member
    4,132
    13
    door is the same, trim is different, but you would strip it down anyway.
    not easier just to get the keyed door painted
  3. cjrob
    cjrob Member
    44
    I was quoted £250 to get the door done, this ebay one is on £60.
    you say the trim is different, just the outer door trim, how easy is that to replace?
  4. Broken Byzan
    13,237
    465
    Looks like a prefacelift door to me, the door handle( as best as i can see) is the old type and the side trim is also the narrow prefacelift one.
    Should bolt straight on !
    The trim will replace if necc, bolts either end ans double sided sticky stuff IIRC
  5. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    also the door is off a saloon so the glass and top door frame is different to your avant, an idea ask the seller to take the glass and top frame off and get a discount on postage may be? as it will be a lighter weight
  6. cjrob
    cjrob Member
    44
    Yikes, totally forgot that it may of been off a saloon, didnt realise I could swap the top frame over either.
    at £60 I recon it worth a punt at least!!
  7. rasA4
    3,287
    119
    no drama not that difficult worth a try for a discount.... defo worth a punt
  8. cjrob
    cjrob Member
    44
    They have confirmed it's off an r reg with facelift rear lights so I have decided to go for it
    Can't wait as the scratches on my current door were doing my head in
  9. voteforpedro
    voteforpedro Member
    632
    That ain't a facelift door.
  10. cjrob
    cjrob Member
    44
    is there a "how to" online to do this, had a quick scoot around and cant find anything, or once the door cards are off is it pretty self explanitory?
  11. Broken Byzan
    13,237
    465
    Once the card is off, it's easy to see, a few cables/wires and 4 x torx screws thingies. Watch out for the wedges dropping out, you will need them for your door, well at least 4 of them anyway
