Rear discs and pads
barkclark Jun 4, 2014
  1. barkclark
    barkclark Well-Known Member
    1,017
    238
    Needing rear discs and pads and I'm wondering where is best to buy some decent ones. I was looking at pagid set on ECP? Also I can't find ones that have the pad wear indicators. Any help guys? Thanks
  2. swarcup
    swarcup Well-Known Member
    1,326
    40
    My rears dont have wear indicators only the front
  3. barkclark
    1,017
    238
    Hmm interesting. The ones I've seen online say 'excluding wear indicators' which suggests some rears come with them but I don't know. My rear pads are shot and my front discs and pads are like new so I doubt it's them that's causing my wear indicator light to come on. Faulty sensor?
  4. ruffrida
    ruffrida Well-Known Member
    1,936
    315
    Only fronts have wear indicators bud
  5. madmike01uk
    madmike01uk Member
    430
    21
    go with pagids, good discs and pads
  6. barkclark
    1,017
    238
    Ah cheers for that. My wear indicator came on a while back but the fronts look bang on. This is why I'm thinking it's a faulty sensor..
    These rear disc and pads look alright?
    http://www.ebay.co.uk/itm/171162052472
  7. A3_130
    A3_130 Member
    85
    Could be a bad connection between the wear sensor on the front brakes and the wire that joins it to the car maybe or the wire might have snapped. Both would give you the warning light even though there might be loads of wear left in pads.
  8. barkclark
    1,017
    238
    Yeah that's what I'm thinking. It'll be worth getting the connections checked when I get the rear disc and pads fitted then!
  9. barkclark
    1,017
    238
    Missed your comment there before posting the link for Mintex ones. You used pagids before?
  10. frankc
    frankc Active Member
    228
    59
    Put new Pagid discs & pads on my Avant last year when I got it, good quality items and no squeal. Got them from ECP on one of heir many discount days so not too expensive either.
  11. barkclark
    1,017
    238
    Pagid it is then! Cheers guys!
  12. barkclark
    1,017
    238
    Just about to order them and I noticed that there is two disc sizes (245 or 255) and different pad thicknesses (approx 2mm difference). Any idea what to order?
  13. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    Probably 245mm if you need 245's I have a brand new set that i bought by accident instead of 255's.
    £25+ postage.
  14. barkclark
    1,017
    238
    Are they pagid ones? I'll check what size I need, if it's 245 I need I'll have them off you!
  15. AudiLeon
    2,250
    192
    Yeah pagid. Got marks on as I fitted one before I noticed. Never used for braking though.
  16. barkclark
    1,017
    238
    Right sounds good to me. I'll need to check what size I need. Most likely it'll be 245! I'll let you know ASAP.
  17. madmike01uk
    madmike01uk Member
    430
    21
    Take your wheel off and measure. Mine is running pagid all round, brakes are real sharp now, they were quite poor before.
  18. barkclark
    1,017
    238
    Pagid sounds good to me then. I'll need to check my discs tomorrow as the weather is sh**e and it was dark before I finished work :(
  19. barkclark
    1,017
    238
    What about front 312mm conversion? Am I correct in saying it's just sourcing some carriers from a 2.5 or 3.0 (and obviously 312mm discs) and nothing else needs changed?
  20. Gazwould
    Gazwould Well-Known Member
    5,763
    2,336
    Correct and worthwhile.
  21. barkclark
    1,017
    238
    Awesome!
  22. frankc
    228
    59
    Or 320mm? Came standard on my 2.5, stop quite nicely...
  23. barkclark
    1,017
    238
    312mm is a very simple straight swap. I have no idea about the ins and outs of a 320mm conversion.
  24. ruffrida
    1,936
    315
    Yeh watch this,m as i got sent the wrong rears and they a massively different, new carriers for 320mm disc though, not sure bout the 312s though
  25. frankc
    228
    59
    Aye having done some reading a swap up to 320mm is a change of caliper from a 57mm piston to 60mm. The 288 & 312mm discs share the same caliper so it's just a change of caliper carrier. Bit too expensive I would imagine.
  26. barkclark
    1,017
    238
    Yeah for the 312mm all you need iscarriers from a 2.5 or 3.0! Same calipers and pads! Finding the carriers is the hard bit!
  27. Gazwould
    5,763
    2,336
    Normally go for around £70 .
    288 Vs 312 :cool:
  28. barkclark
    1,017
    238
    I knew they would look bigger / better but that is seriously better! Definitely need to upgrade them!
  29. frankc
    228
    59
  30. barkclark
    1,017
    238
    I seen that thread earlier. I'm assuming he's selling the full brake setup! All I'm looking to get in the future is carriers. Although it does look like a good deal..
