rear diff
Iceash Mar 26, 2012
  1. Iceash
    Iceash Member
    391
    10
    Hi all, If a rear diff is ill, what's the symptoms?
    When I'm travelling at 30mph I hear a slight wher wher sound from the rear when I pass 30 it goes.
    I'm almost sure it's tire road noise. But thought I'd check with you guys... It is running low profile 17's
  2. aragorn
    18,537
    865
    The diff seals can leak, might be an idea to check and if theres signs of leaking get the oil topped up.
  3. Iceash
    Iceash Member
    391
    10
    looked all dry when I was under there. So they don't make a sound then? lol
  4. aragorn
    18,537
    865
    Not unless they're worn or solidly mounted. My avant has solid diff and subframe mounts and it whines a fair amount.
    I'd ignore it, and see if it gets worse. ;)
  5. Iceash
    Iceash Member
    391
    10
    lol, it' goes after 30mph sure it's tire noise. Solid diff? what's than then?!?
  6. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    Could also be the rear wheel bearings
  7. Iceash
    Iceash Member
    391
    10
    good point :)
