Rear Control Arm, Collar
PDtuning Aug 15, 2014
  1. PDtuning
    PDtuning New Member
    I bought a new rear control arm from the pass and drivers side but took off the arm and found the don't matchstick the ball joint under the hub.
    It looks like a collar is on the arm that came off, do I have to swap this over or should my new are come with it.
  2. mattyb6
    mattyb6 Active Member
    977
    75
    You need to swap it over
    Mine did the same
    Put the collar in a vice and hit the top of the ballpoint and it should drop out
  3. SL11CKK
    SL11CKK Active Member
    712
    That collar should be in the hub. So as above get it off and put it back into the hub or onto the new arm and fit it.
    AudiLeon likes this.
  4. VagCabby
    VagCabby Active Member
    540
    80
    Bit of heat with a blow torch and a vice will get it off
