I've now had alignment done twice and had two reasons given to me why the offside rear wheel can't be adjusted...
It's showing as having very marginal positive camber when I want it to have negative camber to help with the clearance.
First place told me the adjustment bolt is seized and they couldn't sort.. Second place whom I am more inclined to believe have said the adjuster is already at the max and therefore can't be adjusted to make the negative camber switch...
That's a really poor picture but basically there is a off circular shape adjuster that throws the camber when turned and it looks to be already at the wider part of the throw.
Has anyone had experience of this as I understand it may be a common problem. I was asked if the car had been in an accident which I didn't know the answer too but now having checked the paint with a thickness reader it all appears to be factory thickness (with the exception of the work I know i have had done)
Really want to get this resolved but don't want to waste more time and money without actually getting it fixed!
