Rear bulb cluster not working
rossyjr Jan 20, 2014
  1. rossyjr
    rossyjr New Member
    14
    My left indicator when sat in the car is ticking twice as fast as normal, front and side light indicator bulbs are fine but the rear cluster on the car( not the ones on the bootlid) none of the lights are working. One bulb had blown so replaced that but still the same. Replaced all 3 bulbs but still not joy! Help..
  2. rizzini7
    rizzini7 Active Member VCDS Map User
    964
    146
    43
    Could be the pins on the connector have burnt out. Happened on mine. Replaced the bulb holder and all is good again. Assume you've obvious check the fuse
