Rear Brakes on S3 - bearing?
Bam Mar 4, 2014
  1. Bam
    Bam New Member
    13
    Hi all,
    Tried doing a search but couldn't find what I'm looking for...
    Rear brakes need changing over, I was wondering if the wheel bearings are housed in the disc like they were in previous VAG cars I've owned? Anything out of sorts I need to know about or a simple change over?
    Thanks in advance :)
  2. david7m
    david7m Active Member
    551
    44
    I did my pads last month, you need a tool to wind the piston back in.
    Although I didn't replace the discs, I could see it would be very easy with one pozi head screw.
    My car is a 2001 S3.
    Dave
  3. Lewis583
    956
    91
    Bearings and discs are separate fella.
  4. PaulRS3
    PaulRS3 Well-Known Member
    1,230
    156
    From my 8L memory the rear discs are so cheap, it's not worth just doing the pads alone.
  5. jojo
    28,997
    3,649
    This, the rear discs come off the same as the fronts!
  6. Bam
    Bam New Member
    13
    Thanks all!
    Yeh no chance I'm doing just the pads - just wanted to make sure I didn't need to order/pre load the bearings into the discs!
    Thanks again :)
  7. david7m
    551
    44
    Wish I'd looked at the price, they only £20 on carparts4less.
    Dave
