Rear brake upgrade b5 a4 2.5 tdi quattro
adamss24 Aug 30, 2009
  1. adamss24
    adamss24 Well-Known Member
    4,584
    407
    Hi guys, i am thinking of upgrading the rear brakes on me v6 tdi quattro, any suggestions on what will fit ? I am a very competent mechanic so fitting is not a problem. I allready have 312mm front ATE discs and pads and the car stops better than before but the rears looks lost in the arches.
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    see post below yours
  3. aragorn
    18,491
    855
    B5 S4 256x20mm vented disks and the corresponding calipers would just about match those fronts perfectly, as the S4 runs 321mm fronts.
  4. adamss24
    4,584
    407
    Anyone selling a rear brake set-up for the s4 ? Thanks... Really need to upgrade now as i've just got myself an ATE Power Kit with Brembo style calipers and masive 330mm discs and pads. The flexys are missing from the kit but ECP are trying to order me a set wich will take 2-3 weeks to build and send from Germany ?! Thanks.
