Mike whats the PR number mean?
I just rang GSF and they said i need
Rear Pads: 1KO 698 451 C
Rear Discs: 1KO 615 601
What do the last letters signify?
Cheers for your help guys
Pr number identifies the part that is fitted to your car.
I have a 2.0 tdi sportback 05 reg ( MY2006 ) and the PR number for my rear disc brakes,
as indicated on the inside of the service book is 1KD. The ETKA parts catalogue identifies the actual disc size from that PR number. In my case it's 255 x 10mm 5/112. and that is indicated as having the suffix 'K' and the pads that go with it has the suffix 'J'.
Sounds like you have the right ones - just ignore the suffix.
If you need to get any other part numbers you need to give the year and the PR number to be sure it's the right bit !
