rear brake caliper bolts - HELP!
cunningfox Jan 13, 2012
  1. cunningfox
    cunningfox New Member
    Hi,
    Could anyone tell me what size the head of the hex bolts on the rear calipers are and where I can get the tool to remove them from, just getting ready to fit new rear pads, and want to make sure i've got all the right tools ready, already bought the rewind tool.
    Thanks!
  2. Adam.
    Adam. Meow.
    662
    34
    You don't need to remove the hex bolts iirc.
    2 spanners will do.
  3. cunningfox
    Thanks Adam, do I just untighten the bolts on the caliper rather than removing the caliper then?
  4. crunchie
    crunchie Active Member
    880
    77
    The caliper splits from the carrier to allow you to change the pads.
    Only need to remove the carrier if you were changing the discs also.
    I believe they are 7mm cap screws? Please correct me if I'm wrong.
  5. cunningfox
    Thanks, couldn't find a "how to" on this anywhere, giving it a go tommorrow
  6. Roady
    Roady Member
    42
    How did you get on cunningfox?
    I've changed my (old) focus', but not changed my Audi A3's yet... The focus was easy, but getting the right size hex bolt was an utter nightmare!
  7. P10GOT
    P10GOT New Member
    23
  8. P10GOT
    P10GOT New Member
    23
  9. dex140
    dex140 Member
    223
    You will need a caliper windback tool! Other than that its a piece of P!
  10. RobinA3
    RobinA3 Well-Known Member
    1,827
    46
    The rear bolts which hold on the carriers are spline sockets not torx's, do NOT use a torx's otherwise you will round them off.
    Plus they are a git to get on a 2wd A3 and even more a of a git to get to on a Quattro!
    I know as i did a Quattro a month ago and a 2wd sportback last weekend!
  11. Elgy
    Elgy Member
    106
    This isn't really what I wanted to read, as I have mine to do very soon. I did them on a skoda octavia yesterday, and assumed that they would be almost identical to do. Does anyone have any tips to make getting onto the carrier bolts any easier? And my air gun isn't man enough to get the bolts un-done, so I had to use a breaker bar (not easy when working on the floor!).
  12. bodders
    bodders Member
    70
    If you're only doing the pads you only need two spanners and a wind back tool. (IIRC). To just do the pads you don't need to remove the carriers so no breaker bar needed.
  13. Elgy
    Elgy Member
    106
    Thanks Bodders, but I need the discs doind too!
  14. Royceyy05
    Royceyy05 Member
    77
    Have any luck on the carrier bolt size? Come across this and still no answer for myself -.-
  15. Dan2.0TFSI
    Dan2.0TFSI Member Audi A3
    47
    24
    Holy thread resurrection. lol.
    I did a bearing this year and had to remove the carrier. The carrier bolts are not spline bits. They are 'triple square'. iirc they are 14mm. They don't come out very easily if they have been on for a while. Be patient.
  16. Royceyy05
    Royceyy05 Member
    77
    Thanks Dan! :) I recently had new discs and pads so I think they should be okay :) any idea how much you tighten them? Don't want to go stupid on them.
  17. Dan2.0TFSI
    47
    24
    Not sure of actual torque value. I just did it up tight. Not swinging from the ratchet tight but enough to be happy.
  18. Royceyy05
    Royceyy05 Member
    77
    Okay mate, cheers for the info :) how much are they roughly? Need to purchase one for the weekend
  19. Dan2.0TFSI
    47
    24
    I brought a set of five. Was about £12. Glad to be of help.
  20. Royceyy05
    Royceyy05 Member
    77
  21. Dan2.0TFSI
    47
    24
    I have Bergen ones. Also from the bay. They took a massive amount of torque without shearing.
  22. Royceyy05
    Royceyy05 Member
    77
    Any recommendations then Dan? :)
  23. Dan2.0TFSI
    47
    24
