Rear Badge
haids Aug 6, 2007
  1. haids
    haids New Member
    I have noticed that some Audis with the 2.0 T FSI engine have got a Red "T" badge on the rear boot lid next to the "2.0" and some have a silver "T". Mine has a silver one and yet it's an S-line. Does anyone know why this is. I think the red one looks better.
  2. emzino
    emzino Active Member
    1,231
    Maybe the ones with 2.0T are Quattro
  3. Amchlolor
    Amchlolor Active Member
    5,604
    Quattro's are badged quattro,aren't they ?
    VW use red T's to signify power output,I think.
    Red T means it's the 'hot' version.
    EDIT- there's something on another Audi forum that states it's purely down to model year.
    2006 models had the red T.
    2007 models have the silver T.
    Simple as that !
    (or the other way around,can't remember)
  4. Dandle
    Dandle Member
    852
    My 2006 2.0T has a red T, other peoples cars picked up the same time as mine started to come through with either colour T. The power outputs are the same for both colours although like Bowfer said earlier 1.8T units used the colour to signify higher output engines.
  5. h5djr
    9,466
    1,773
    Bowfer is right, it does depend on model year. The parts catalogue lists two part numbers for the 2.0T badge.
    One covers models from 04/04 >05/07 - 8H0 853 743 H and there is a second part number 8P0 853 743 G which covers models from 06/07 onwards.
    Unfortunately the catalogue does not say which one has the red T.
  6. emzino
    1,231
    When I said the T is ones with Quattro, of course I knew it had the Quattro badge too but just thought you get the Quattro badge, and because of that you get the T too. Just clearing that up so I don't look like a tool lol.
  7. Amchlolor
    5,604
    According to several sites,red nail varnish works well !
    Personally,I'd be digging out the old airfix enamel and brush.
  8. OutLore
    OutLore VOIP Dude
    1,206
    Mine came with a silver T, so I promptly bought a red one from VAGParts.
    Not sure why they are different though, but I am sure all the 07's I have seen have had silver T's....
  9. Shao_khan
    Shao_khan Member
    253
    Historically Audi and VW have done this when they have several varients of the same engien in a range - Golf, Bora and PAssat all had various red badges on TDI models - REd I, Red DI and it came from different outputs on the 1.9 unit. Audi have doen it in the past as well with 1.8T engines 163 with all silver, 190 with red I.
    If I remember rightly Audi had a badge for a while which was a silver T with a red slash to indicate the higher performance - could look quite unique if its still in teh same font.
  10. siu00adg
    siu00adg Member
    997
    Saw a 2.0FSI today, I wonder if its any different to the 2.0FSI
  11. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    I have an 06 (56) 2.0T with a silver T. Or is mine actually a 07 model. I'm still a bit confued by the whole MY etc thingy.
    Nevermind.
  12. h5djr
    9,466
    1,773
    The best way to check on the Model Year of your particular car is to look at the VIN number:
    WAUZZZ 8P 3 7A123456
    In this example VIN Number...
    The W indicates the car was made in Germany (original West Germany)hence the W
    The AU indicates the manuafacturer was Audi
    the ZZZ and the 3 are just filler numbers and a check digit
    the 8P indicates the Audi Model type
    the 7 indicates it Model Year 2007
    The A indicates it was made at the Ingolstadt plant
    a B would indicate it was made at the Brussels plant
    and the 123456 is the serial chassis number.
    Audi change the VIN numbers and the production model year on 1 June each year.
  13. Staz
    6,206
    67
    well it'll be a 07 then as I ordered it after 1st june and picked up october.
  14. mrsteve
    mrsteve Member
    64
    I have an 05 sportback and mine has a red T, didnt realise you could get silver as well... :/ my old TDI was all in silver.
  15. MJZ 6370
    MJZ 6370 Member
    41
    I have just taken delivery of my new MY08 2.0 TFSI and it has a silver T.
  16. JED
    JED Member
    55
    Someone I knew bought an A4 2.0T back in Feb 05 and it has a RED T. Newer models have a silver one.
