REAR AXLE FRONT BUSHES
tonya4 Jun 20, 2011
  1. tonya4
    tonya4 TDi Powerrrr
    408
    I noticed today that the front bushes on the rear axle aren't looking to healthy.Is it worth putting poly bushes in or just new oem ones?
    thanks in advance
    tony
  2. aragorn
    18,608
    871
    New OEM ones will make a huge difference, and cost about £7 each.
  3. tonya4
    tonya4 TDi Powerrrr
    408
    thanks for that.
    Are they difficult to fit?
    tony
  4. Jason.s
    Jason.s Active Member
    2,879
    348
    More like 27 plus vat for genuine..each
  5. aragorn
    18,608
    871
    I baught mine from AllGermanParts.
    A lot of the stuff is real Audi parts and someones just ground off the Audi rings and removed the Audi tax along with it!
  6. tonya4
    tonya4 TDi Powerrrr
    408
    are they hard to fit?
    thanks
    tony
  7. Jason.s
    2,879
    348
    When they do them at work on other models which have similar they end up ripping the rubber out and then using an air chisel to get the casing out. Then the new ones slip in pretty much. Can be done on a drive its just not the easiest job to do. Bit of brute force is needed to get them out and various cutting is required. Also heard freezing the new bush makes it easier to get in.
  8. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,005
    764
