Rear ARB on 2000 A3 1.8T??
Dennis Moeller May 3, 2009
  1. Dennis Moeller
    Dennis Moeller Member
    444
    Mate of mine has an A3 1.8T from 2000 front wheel drive. He changed all of his suspension yesterday but was baffled that he couldn't locate the rear ARB (he did change the front ARB but wanted to check what size the rear had for later modding). My question (for him): Are there any rear ARB on this particular model...
  2. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Mines got one, same car, same year so not sure whats going on there:blink:
  3. Dennis Moeller
    444
    ?? hmmm...I took a look just now and there's a bar that runs "inside" the rear axle...Is that the one...don't see how we can get it out?
  4. Broken Byzan
    13,237
    465
    There isnt one on a 2wd car. It has a torsion beam axle and the axle itself acts like an ARB
  5. Dennis Moeller
    444
    Cheers Mates!! We will leave the rear axle to do the job then :)
  6. A3Tom
    3,504
    14
    So whats the bloody great big yellow KW thing stuck to the back of my car then? :blink:
    Mines a 2000 1.8TS 2wd and its got one, I've just been to check to make sure I wasnt imagining it......I wasnt, its there!.
  7. Dennis Moeller
    444
    This I like more ;-) Now there's hope again! If you have a weblink or if you one day have a cellphone in your hand while bending down behind the car (Yea I know...)...could you throw a picture my way. My mate would be thrilled to know this...his car REALLY needs the ARB as the front don't seem to be quite effecient enough...
    Thanks again!!
  8. Dennis Moeller
    444
    We've just been out in the garage and had yet another look...We can't seem to find any mounting points...does it connect to the same place in which the rear dampers are fixed (at the bottom of the damper?) with one bolt and nut?
  9. A3Tom
    3,504
    14
    Hold on chap, I'll pop out and hope my neighbours dont notice me crawling about on the drive with a camera :laugh:
  10. A3Tom
    3,504
    14
    Here we go, bolted through where the bottom of the shock is fixed.
    Cant remember what was there before to be honest though.
  11. Broken Byzan
    13,237
    465
    Thats because nothing is there normally, its a complete setup, and iirc no longer available, tho i expect to be proved wrong on that too,lol
  12. A3Tom
    3,504
    14
    I cant remember what was there to be honest, I'm sure someone will come along and tell us all though!.
    There are loads of front and back ARB kits available for the 1.8T Sport. Eibach do one, mine are KW.
    T
  13. HTC
    HTC Active Member
    3,428
    9
    There is a stock rear arb. You need to look inside the rear torsion beam. It's not very big.
    One of the best handling mods is a second rear arb for the 2wd cars.
  14. abdus
    abdus Top Gear VCDS Map User
    1,827
    A3Tom, did you assume this big yellow bar on yours to be standard?
    yeah, as HTC said, one of the best mods. Mine is an eibach.
  15. Broken Byzan
    13,237
    465
    Perhaps i should have been a bit clearer, there is no ARB as STD on the rear of a 2wd A3. On those points on the bottom of the shocks is normally nothing but the shock securing bolts, and as you can see the other mounts on the aftermarket ones are added.
    The B5 A4 rear has been discontinued and you lucky 8L lot still can buy kits for yours
  16. Dennis Moeller
    444
    Cheers Mate...you're the man of the day. Wonderful!! Mate will be one happy camper.
    Even tho it's not standard with a rear ARB on this model it certainly needs it!!
    Thanks!
  17. A3Tom
    3,504
    14
    nooooooo, I know its not the standard one as I had the front and rear KW's fitted not long ago. I just never paid any attention to the old rear set up.
    It really sorted out the handling to be honest, not sure why they dont have a decent one as standard to be honest.
