Real world 0-60 S3 Sportback manual
Gandy Jul 12, 2012
  1. Gandy
    Gandy Member
    51
    I have an iPhone app called g-tac which measures acceleration using GPS. I just gave it a try just now on a 0-60 run stats below.
    0-30mph 2.21s
    0-60mph 5.97s
    I fluffed the change to 2nd gear which cost me time, so could definitely go quicker. I am running Stage 1 shark.
    Other stuff:
    Traction control on
    Roughly 5k revs at launch
    Only need second gear
    AC on (it's hot!)
    I have Opensky which I assume adds weight
    Has anyone else tried similar and have verified times either GPS or from say RWYB days?
    Any suggestions for a better time other than not messing up the gear change?
    G
  2. maninthestreet
    maninthestreet Member
    152
    15
    Where in the UK is it 'hot' ???
  3. Gandy
    Gandy Member
    51
    It is over 20 degrees in Harrogate at the moment. Must be a freak!
  4. discostu49
    discostu49 Active Member
    598
    132
    43
    get the air con off for your run i heard it uses power aswell as fuel
  5. S3Alex
    10,767
    4,791
    Cooler weather equals lower intake temps equals more power.
  6. audicruiser
    audicruiser Audi Heaven
    1,865
    New clutch on the cards too by the sound of it!! :ohmy:
  7. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    4.26s 0-60 on my S2+ STronic S3 :) Using Dynolicious app.
  8. mjr901
    mjr901 Guest
    using that app called g-tac I've just done a 3.23 0-60. (stage 2) hmmmmmm don't think so.
  9. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,019
    551
    lol :D
    i don't know mine but it's much faster than anything on the road :D
  10. ilim
    ilim Active Member
    665
    41
    My car goes in to Warpspeed... The date on my iphone changes to like 3012 and then comes back to 2012 when slowing down.... :w00t:
  11. RPB
    RPB Active Member Team Ibis Audi S3 Black Edition DSG
    399
    70
    Sod them rubbish app's, I may have to dig out my Racelogic Vbox and give it a go in the S3.
  12. S3Alex
    10,767
    4,791
    The apps rely on the phone's internal accelerometer,plus the thing being properly calibrated and the phone then fixed securely to the car.....most of which don't happen,so you get results from disappointing through to amazing.
  13. MACCAA
    MACCAA New Member
    29
    "Only needed second gear"
    Don't believe an S3 will do 60mph in second gear...hope you weren't going by the optimistic speedometer.
    60 on the speedo is about 56 from memory.
    And Traction Control "On"???[And A/C]...
    Only thing achieved here was some mechanical abuse-and then people wonder why their clutch slips...
  14. Gandy
    Gandy Member
    51
    That's fast! Benefits of S2+ and STronic. Do you have some kind of launch control like in the RS3?
    Regarding some of the other comments, I agree I am not 100% sure the app is any good. The manufacturer claims 'g-tac is the first car performance meter app to use both accelerometer and GPS for the most accurate results', and I know that Dynolicious uses GPS too. GPS should be more accurate than just using the accelerometer. I did also record an 11.3s run which was clearly wrong! A vbox would of course be much better.
    Regarding the accuracy of the speedo, according to my GPS the speedo is within 1mph of being correct at 60mph. As I said in the original post I wasn't using the speedo to measure speed, rather the GPS based application on the phone. 60mph is definitely achievable in a stage 1 car in 2nd gear. Before I had it mapped it topped out at about 56 before bouncing off the rev limiter. Now it goes up to about 63/64 before hitting the limiter. Dependant on how the traction control actually works it may or may not make it faster. I would be interested in people's experiences in this case. As for slipping clutches, with occasional abuse mine has already done 10,000 miles and shows no signs of slip. I'm sure doing this kind of launch daily would kill it in a month.
  15. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,215
    2,031
    Alex you've ruined lots of members pub ammo saying that :)
  16. mjr901
    mjr901 Guest
    Forgot to mention it gave me the 0-100mph figure too.... 5.98 hahahaha gotta be right!! :p
  17. S.
    2,019
    551
    remap doesn't change your gearbox ratio. you can hit in 2nd 60mph but not 62. mine never did. not on stock, not on stage 2 map, not even on stage 2+ map.
    also for measuring i would recomend elm obd2 bluetooth device which sends data to mobile phone trough Torque app on Android. it reads data from cars ecu so it would be more accurate than other mobile apps. and it cost 10$. you can also use it to read other data, such as intake temps, boost, maf readings, timing, o2 etc. and you can read DTC's and reset them.
  18. S3Alex
    10,767
    4,791
    Had to be said!
    In any case,I don't think the traffic light drag contest is very useful.....I've always said that 30-130 or real on-road in gear performance is more important.
  19. essIII
    essIII Active Member
    285
    35
    Remap doesn't change the gearbox ratio, but does it not move the limiter further up the rev range? I'm sure since Stage 1 Revo mine goes further into the red before hitting the fuel cut off? Higher available revs + same gear ratios would = more speed in 2nd.
  20. S3Alex
    10,767
    4,791
    The limit isn't usually changed,but you may well find the car is able to get a lot closer to the limiter due to better boost.
  21. Gandy
    Gandy Member
    51
    Bluetooth device sounds good, I will look it up.
    You are right that the gearing does not change. The important factor is where the rev limiter is which is about 500rpm higher on my stage 1 map. This allows a higher speed in any given gear. Imagine if the rev limiter was set to say 3,000rpm, you would not be able to do more than about 35mph in second gear. The reverse is true when the limiter is raised.
  22. S.
    2,019
    551
    thats also true :D
    but i don't really like to rev it to 7500 rpms.
