Readiness test ?
darren t Apr 9, 2013
  1. darren t
    darren t Member
    568
    So I thought I'd check my readiness using vcds and everything passes except catalic converter,I have tried passing manually but can't get block 034 in basic settings too initiate??? The value was 1.78 but hadn't passed the test all other tests passed but this one?
    Pre cat sensor is a couple of months old tops!
    Getting some /white/grey smoke on startup untill warm short term fuel trim after reset was 2.1 which indicates a vac leak?? Ltft was still 0?,when on full throttle I have been told I'm chucking a tad of black smoke out?? Turbine blades on exshaust side were black with soot when I had down pipe off my previous turbo was white inside running nice??could I be overfueling on idle??? going too double check carbon canister pipe work today as some have reported rubbing on washer bottle?
  2. vivalacoulter
    vivalacoulter Active Member VCDS Map User Gold Supporter Audi S5
    409
    61
    Did anything come of this after?
  3. darren t
    darren t Member
    568
    Yes there's 2 other test need passing first they have too be done in certain order! When it comes too cat temp must be above 450! For test too start and revs need holding at 2500rpm (steady)!!!audi use special tool need a steady foot!i fitted new vvt tensioner aswell before test was done new oil ect not had any problems since and my fuel trims are bang on short term 1.3 and long term 0.8
