Re the CTAADUSB003
LEE69 Aug 19, 2013
  1. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,147
    376
  2. LEE69
    2,147
    376
    Google is ace for anyone else when searching
    aminder likes this.
  3. T8DPR
    T8DPR If Carlsberg Made Audi Drivers...
    551
    98
    if you're using aux-in I don't think the folder system is necessary, that's just if you use the SD card slot or the USB stick, I use the USB
    you should also know that if you have a LOT of tracks (maximum 99 per folder) it can struggle to keep up with what order it plays them in, and you also cant set it to have a specific playlist, it'll just play the folder contents in its own chosen order
    but to answer your main question, it doesn't show track ID on the display
    google will give you the installation instructions in better detail than what come with it
  4. LEE69
    2,147
    376
    Thanks ordered one earlier and the removal keys.
  5. LEE69
    2,147
    376
  6. LEE69
    2,147
    376
    Also what is the difference between the Audi concert and Audi concert 2
  7. T8DPR
    551
    98
    mine is the older one, single din, I think you might need the 004 one, I hope you haven't bought the 003 that I needed
  8. LEE69
    2,147
    376
    No, i bought the 004 one after checking the dates the seller said for the cars
  9. Keyz
    Keyz A3 2.0TDi S Line VCDS Map User Audi A3 S-line owners group
    156
    22
    Im glad someone is talking about this as I have been messaging the same people today about buying one. I have the single din concert and I was going to get the 003. Im just waiting for their response after I sent them a pic of my connectors to see if it was correct.
  10. LEE69
    2,147
    376
    Anyone know?
  11. T8DPR
    551
    98
    mine is the one K9 has pictured and I have the 003 fitted, it should come with the necessary wiring harness too so you will get everything you need to plug and play
    LEE69 i'm not sure feature-wise what the difference is between concert 1 and concert 2 because I think the audi a3 8L has concert stereos which maybe concert 1 and I don't know if it differs from mine/K9s
  12. Sidhu88
    Sidhu88 Active Member
    808
    76
    004 is correct. Have you checked to see u dont already have something in the slot where this goes in on the quadlock?
  13. LEE69
    2,147
    376
    Not got the keys till they are delivered.Where, if i do have anything in the slot, does it end up?
  14. LEE69
    2,147
    376
    All fitted right doddle tbh.
  15. LEE69
    2,147
    376
    There was something in there, might be something to do with the audi phone holder the car as got? Couldn't see where it plugged into anywhere when the glovebox was out.
  16. Keyz
    156
    22
    ok got mine delivered this morning... Missing some cobles and NO instructions... Going to attempt this without them and see how it goes.
  17. LEE69
    2,147
    376
    Post back if you get stuck, simple job really
  18. Keyz
    156
    22
    Hey Lee... all in and working but did have a few problems, little wires in one of the blocks had come out so I had to work out which ones went where. If using the usb do I need folders and can I just put the files all in one place directly on the stick?
  19. LEE69
    2,147
    376
    Yeah just make six folders then each one is accessed by pressing the numbers 1-6 around the edge of the stereo.Not tried SD cards yet or phone
  20. Keyz
    156
    22
    Great, I can choose which songs I want in each then.. Thanks mate.
  21. LEE69
    2,147
    376
    Yeah, it doesn't id tag them on mine.
  22. Keyz
    156
    22
    Not too bothered about tags but Im not happy they didn't give me a cable for my ipod so cant test it out yet. As long as its in im happy.
  23. LEE69
    2,147
    376
    I got no ipod one which is a good this as i'm android ;) I got a usb extension lead and the one for the 3.5mm input.
  24. Keyz
    156
    22
    Yea I had extension lead but I plugged pen drive straight into it. Haven't tried SD Card yet though. They must have forgot to put in the 3.5 cable, I have told them so hopefully they will send one out to me.
  25. T8DPR
    551
    98
    I don't understand how the instructions that (occasionally) come with them are so ****!
    I googled it but its easy for someone who doesn't know their way around wiring to really balls it up
  26. LEE69
    2,147
    376
    Had mine since 21/08/13, but it is hit and miss if it reads the usb sticks.I have several here and only 1 cheap freebie one i got works. The SD slot reads 5/6 of the albums, sometimes all 6.
    Just wondering if anyone else is having or had similar problems
  27. Keyz
    156
    22
    Mine is the same mate, won't even read anything sometimes.
  28. LEE69
    2,147
    376
    That's good news but not for us if you get what i mean.Mine is still under 12 months warranty with the ebay seller.
    How old is yours?
  29. Keyz
    156
    22
    I only bought my car last July. Think I bought it around about August but not sure if they said I had a warranty or not.
  30. LEE69
    2,147
    376
    I got mine of ebay, you get 12 months warranty, as long as it was new :)
  31. T8DPR
    551
    98
    Mine's been faultless with an old broken mp3 player which I could still use as a USB stick, my newer mp3 player, tho both of these are sub £5 jobs off ebay, I stopped using them in favour of a space saving 2gb SD card cos it doesn't stick out
  32. LEE69
    2,147
    376
    Just bumping this mine has been returned the usb reading is so hit and miss even with 4gb max stick they say to use.They are testing it.
  33. LEE69
    2,147
    376
    Just had word back a new replacement is being sent out.
  34. T8DPR
    551
    98
    that's a bit cack innit! how long have you had yours? I was warned early on before buying that if you have a hell of a lot of stuff on it, its got a 2gb card in atm I think, but about 30 tracks in each one, on the odd occasion it'll struggle to find a song and skip to the next, or sometimes it'll play a different song than what its meant to, but it's never gone actually faulty
  35. LEE69
    2,147
    376
    Bought it last August.Apparently ebay items have a 3 month warranty, go in touch with connects2 and they said send it back via the ebay seller, and got word today that a new one is being sent out.
  36. LEE69
    2,147
    376
    New one all fitted, so that's how they are supposed to work lol
