Re Soldering Bose amp on '04 Tdi Sport
sinic Mar 21, 2012
  1. sinic
    sinic Audi WAudi
    250
    Can anyone point me to a guide to re solder the bose amp on my tdi sport?
    I have crackly rear tweeters when cold so assume I have the dry solder connections on my amp??
    I'm not afraid to solder and want to do the job asap
  2. AndyMac
    9,832
    45
    If it's just the tweeters then it won't be the amp as the tweeters run off the same feed as the woofers
  3. sinic
    sinic Audi WAudi
    250
    I think its just the tweeters but not 100% sure, sounds like the tweeter coming in and out when I'm driving along....it's just on the drivers side behind me in the rear right door....
    Any suggestions?
    When it's all warmed up its less intermittent, same as if I whack up the volume it then kicks in.....
  4. AndyMac
    9,832
    45
    More likely it's a dirty door connector if whacking up the power cures it, common problem on the B6, you need to remove the rubber boot and clean up the plug.
