RE-SET DSG MEMORY (IS IT POSSIBLE)
RGC Jun 14, 2009
  1. RGC
    RGC Keep on rollin
    150
    As per title, is it possible to reset the DSG memory as to re-learn it to a new driving style?
  2. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    I'm pretty certain that the re-calibaration is NOT what you asked for. -You asked about clearing the 'driver habit' learned part of the transmission. -Be Warned.
    The DSG calibration (so far as I recall) is about setting things like the "Bite points" (takeup points) of the clutches etc.
    Keith
  3. RGC
    RGC Keep on rollin
    150
  4. RGC
    RGC Keep on rollin
    150
    maybe yes, is it possible to clear this?
  5. Let me explain this to you again if you perform all of the steps from the ross teck site the DSG will load the "factory defaults" and will re-calibrate it's values with the ones that are currenly given by it's mecatronics sensors.
    f you have any other questions let me know.
    best regards,
    ANdi
  6. dc240969
    dc240969 Member VCDS Map User
    927
    RGC, mm. Lower Methil maybe?
  7. RGC
    RGC Keep on rollin
    150
    OK i am not sure how to follow the steps from the Ross tech as it seems mumbo jumbo, i have the full licensed vag-com, how do i do it, just go down the list or just go strait to reset?
  8. RGC
    RGC Keep on rollin
    150
    ???? what ????
  9. Mate please perform all of the steps from the ross tech page in the prescribed order, DON'T jump any of these steps. Also it is wise to perform
    Defined Test Drive
  10. RGC
    RGC Keep on rollin
    150
    when it shows
    Activate the Basic Setting.
    [ON/OFF/Next]
    what does this want me to do? click on and off and next ????
    ???? wtf
  11. RGC, click ON and then wait for the adaption, do this for all of the modules mentioned on the ross tech page.
  12. RGC
    RGC Keep on rollin
    150
    Right, i will do this, first i will go for a drive to get the car up to temperature.
  13. RGC
    RGC Keep on rollin
    150
    all done. :shutup2:
  14. RGC when you did the adaption for the first module did you hear a strange noise coming from the dsg box? If you did relax it's perfectly OK :).
    BTW: glad that helped you the post ;)
  15. RGC
    RGC Keep on rollin
    150
    yw influxsg, :salute:
    yes a couple of loud clunks, i had already read this would happen on another post, I thought some one was knocking on my window at first :arco:
  16. Great mate, please tell me what version od vag com did yuo use?
  17. RGC
    RGC Keep on rollin
    150
    Release 805.4
    only just updated it today
  18. MrTea
    MrTea Member
    53
    I had Audi do the following for me back in Feb:
    "Carried out re set of learned values and carried out basic settings for clutches and gear actuator"
    What are you hoping to achieve with your reset?
    I was trying to improve the responsiveness and smoothness of the ride but I can't say it made any difference for me.
  19. just017
    just017 Member
    436
    Yeah i have the DSG box, what is this reset meant to do?
    Does the box adapt to driving styles or something?
  20. I have a question how did you find the Control Module Software Version?
    many thanks
  21. RGC
    RGC Keep on rollin
    150
    i was having problems with the dsg box wanting to change gear from 2nd to 3rd and then deciding not to resulting in a blip of no power, it was like i was letting off the accelerator for a split second, this only happened if i was only lightly accelerating, it was not affected when i was heavy accelerating.
    i have also noticed since the recalibration the gearbox does not tend to race through the gears when driving slow, it seems to be working allot better than it did before the re-cal,
    hope this helps
    Richy
  22. I did this re-calibrating but at the final two modules:
    Reset Values (Steering Wheel Paddle Installation)
    Group 063
    and
    Reset Values (ESP & Tip Cruise Control Installation)
    Group 069
    Only the OFF value appeared it never changed to ON, is this OK?
    Many thanks,
    ANdi
  23. RGC
    RGC Keep on rollin
    150
    I don't have the cruise installed so that module was not active but
    as long as you don't get any fault codes which wont clear your OK,
    Richy
  24. Cool RGC thank you, by the way did you feel something different after you reset the dsg, i mean the driving experience.
  25. RGC
    RGC Keep on rollin
    150
    yes the dsg box seems different, it does not try to get to 6th as fast as it normally would, it tends to sit longer in 4th which is great because the power is there when i want it, ;)
  26. MrTea
    MrTea Member
    53
    Glad it improved things for you. I have the opposite problem to you - mine changes down gear too quick into 3rd and 2nd resulting in some nasty engine braking. It's equivalent to applying the brakes too hard and being lunged forward.
    Audi checked it and they seem to think this is normal but I disagree and it's going back to Audi again. I can also sometimes hear a clunk when the clutch disengages when braking.
    Not sure if that is normal :uhm:
  27. RGC
    RGC Keep on rollin
    150
    no thats not normal, you should not hear any clunks what so ever, it should have smooth and quiet gear change (up and down), all tho the clunks could be a result of the malfunction.
    It sounds like there could be a speed sensing problem, your DSG box may think its travailing at a slower speed than it is resulting in early down shifts.
