Re: Ran out of fuel......help.
halfcab Apr 10, 2006
  1. halfcab
    halfcab New Member
    Rather stupidly think i ran out of fuel!
    98' A4 19tdi Avant, slowly coasted to a halt in my works car park, so went and got some more fuel but no joy. Engine crank's but does not fire.
    I think I may have an air-lock, and have heared that there may be a bleed valve in the engine...but where??
    Any help advice would be great.
    Cheers.
  2. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,742
    165
    I had this other day!! low fuel in tank...car completely cut out. turned over but no fire....all i did was disconnect battery for 5mins and it reset ec.
    Car started fine and ran fine but the 'glow plug' indicator started flashing after 30secs....indicating a fault.
    upon pluggin in my laptop with vag-com it had two faults logged...
    misfire on cylinder 3 due to lack of fuel
    low fuel sensor activated.
    cleared them and now the car is back to normal.
    So if you dont have vag-com you may be in for a visit to the stealers and pay for a complete clear of the fault codes.
    hope this helps.
    Dan
