Re-mapping my 04 plate A4 2.5 v6 tdi cab
thekoplfc Jun 12, 2012
  1. thekoplfc
    thekoplfc New Member
    please would like any advice when it comes to remapping my audi
    i would like better acceleration and mpg but bit worried because ive read about temp getting to hot
    please advise me thanks
  2. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,286
    627
    Hello,
    if the cooling system is working as it should, there should be no problem with it getting hot.
    Thanks, Rick
  3. Mike B
    Mike B Well-Known Member
    1,115
    40
    Mines got a tuning box which does both
  4. quattrojames
    14,068
    585
    It shouldn't be any more prone to overheating just because it's been remapped.
  5. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    60
    kop, is yours a manual / multitronic? a lot of those cabs are multitronic and I know they don't like remapping as it allows much higher torque levels at lower revs...
  6. Inertiauk
    Inertiauk Active Member
    575
    29
    I would presume it will have an EGT sensor and the ECU will back the boost off for safety if things get too hot ?
    Im only presuming this though, as its how other cars work, don't know for sure, can someone confirm ?
  7. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    Egts won't get that hot. You wouldn't be run that lean to create high enough gets to cause problems
  8. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    To be honest, remapping wont really increase temperatures.
    Even if it does, the viscous fan is capable of flowing alot of air.
    It will be exactly the same at idle - I really wouldn't be worried about temperatures at all.
