? re injector removal
epox Jun 15, 2013
  1. epox
    epox Active Member
    772
    74
    hi i am going to replace the filters and seals on the injectors, just one question is the fuel still under pressure when the engine is off?
    if so wath the best way to remove the pressure
    thanks mark
  2. superkarl
    superkarl MAN OF STEEL
    9,428
    2,394
    It will be under some pressure yes. Get a large thick rag to cover your engine and when you pull the injectors the small amount of fuel will be soaked up.
    Maybe worth removing the fuel pump fuse too, although i cant remember the number. DO NOT cycle the ignition, it will prime the system ready for start up, (hence removing the fuse is a good idea)
  3. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,144
    1,975
