Re dis and cruise retro fit,
trickybusa Dec 5, 2013
  1. trickybusa
    trickybusa Member
    Hi All,
    I have fitted the stalks for dis and cruise and now need to get them activated which I'm going to do soon with a vagcom. My questions are, what is the code as Ive seen the cruise control code but not the cruise and dis code, also do I need to do a wiring mod/washer level sensor mod.
    My car is a 2006 2.0ltr tdi 170bhp A4 Avant.
    Cheers Rick.......
  2. trickybusa
    trickybusa Member
    Well it must have been something I said no reply's and someone else asks a simlar question and gets a reply instantly.
    Confused.
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    If they asked similar then is your question answered?
    Chances are whoever uses vcds to code them in will already know the codes to use :D
  4. Andy27168
    Andy27168 Member
    130
    9
    Hi,
    I recently did this to my B6 S4 Cab, and I was a bit nervous about doing it as I had never coded cruise control before, I can honestly say it was a doddle though I had to fit a new SCM and clock spring as well though DIS was already factory activated, the coding.
    All the info is on the Ross Tech site, I also used their utube videos as these made things a lot clearer, especially when coding the ABS module (you might not have to do this) just make sure you take an auto scan before of the car before you start changing codes.
    Regarding the question you asked you will need to change the fourth digit of the soft coding of the SCM from the existing number to a 4 "Board Computer and Cruise Control".
    See link below,
    Audi A4 (8E) Steering Wheel - Ross-Tech Wiki
    To activate the Cruise control you will need to recode the Engine ECU link below,
    http://wiki.ross-tech.com/wiki/index.php/Cruise_Control_Retrofitting_(8E)
    Regarding the Washer Bottle I,m not 100% sure as I,m sure I have read that some cars possibly just B7s MIGHT come with the level sensor from the factory, I might be completely wrong, you could just wait till its coded and see if you have warning light come up, and then sort it, or you could look at the how to on the site somewhere to see if the connector behind the dash has a cable in it in which case you have the level switch fitted.
  5. trickybusa
    trickybusa Member
    Like I said similar, basically half the question answered :)
    Ok are there any Vagcom guy's around the bradford area that can enable the Dis and Cruise stalks that I have fitted. I will run the wire from pin one myself.
    Cheers Rick......
  6. trickybusa
    trickybusa Member
    Cheers Andy27168,
    I think if there is anyone local I will see how much it costs to do as I don't want to make a mistake trying it myself. The cruise looks simple and I can get a vagcom to use but the lack of info on Dis makes me nervous.
    Cheers Rick..............
  7. Andy27168
    Andy27168 Member
    130
    9
    Where in the UK are you Rick? If you are within travelling distance of Southampton I,ll do it for you.
  8. @udi A3
    1,820
    197
    Im about an hour from bradford, welcome to take a run down the A1.
  9. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    883
    Im about 4 hours from Bradford ..................lol. Recoding of this will take about 10 mins.
  10. trickybusa
    trickybusa Member
    Cheers all for the reply, @udi A3 cheers for the offer Im bit stuck on time at the moment that's why I hope'd someone local could help. As a guide how much should it cost me.
  11. craigynett
    craigynett Member
    294
  12. trickybusa
    trickybusa Member
  13. hades-
    9,481
    646
    the dis is very easy to do
