Rattly engine when started?!?!
Bean5 Oct 24, 2012
  1. Bean5
    Bean5 kidney bean
    341
    Hi guys, noticed today for the first 5-10 seconds of starting my car, engine sound a touch rough/rattly/dry... A bloke I work with reckons its the injectors need a clean... What dya think???
    And if it is likely to be this is it just a case of getting some injector cleaner?
    cheers
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    what engine?
    could just be the lack of oil around the engine most rattle a little for a few seconds till the hydraulic followers get some oil
  3. Neilb1
    Neilb1 Member
    178
    could try a thicker oil in it with the weather getting colder
  4. Bean5
    Bean5 kidney bean
    341
    1.8t cheers
  5. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    *thinner.
    This could possibly be due to the oil strainer being slightly clogged and not supplying oil to the top end quick enough.
    The oil strainer clogging is a common issue with the longitudinal 1.8T engine.
  6. Neilb1
    Neilb1 Member
    178
    try thin oil for the winter because the cold temperatures will cause the oil to thicken slightly. Likewise, you want thicker oil for the summer because the high temperatures will thin the oil slightly.
