Rattle ,Rattle , Rattle
CheekyAudi Jul 26, 2011
  1. CheekyAudi
    CheekyAudi New Member
    13
    Hi people,
    Ive a 1.8 A4 `99
    Theres the most annoying rattle coming from the rear o/s wheel area , its happening when going over even the slightest bumps or uneven road and sounds like ... eh imagine jingling 4-5 washers together in your palm that sort of metallic pinging
    Any help as to where to start looking? , i can almost replicate the noise by banging on the tyre with my fist.
    Ta
  2. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    165
    Loose Brake pads or anti rattle spring maybe?
  3. Bradderz_1988
    3,951
    235
    Balance wieght, centre cap clip or disc shield.
  4. ldoshiv2
    ldoshiv2 Member
    82
    im having the same problem with the front of my car mate, although mines sounds louder than a few washers. you can reakky hear it with the window down,. i originally though it was a rattling drive-shaft but ive been told it could be various small things to do with your brake pads/caliper or carriers. but im going to have a go at these. here is a link to the pins, i don't know the correct name and this is all i can find, hope this helps,
    Audi A3 A4 Brake caliper pad wire set H1123 | eBay
  5. AR-rkon
    1,913
    165
    if you have the 228x25mm disks, the anti rattle spring is p/n 4A0615269
    the 280x22 dont have one fitted
    321x30 (the mahoosive FF ones) have a spring 4B0615269A
    Your brakes are most likely to be 280mm or 288mm
  6. Bradderz_1988
    3,951
    235
    The noise is from the rear so doesn't have anti rattle springs on the rears and I'd say your front disc are 280mm with it being a 1.8 N/A.
  7. AR-rkon
    1,913
    165
    oops didnt notice the "rear" bit :blush:
  8. Bradderz_1988
    3,951
    235
    Have you jacked the car up and felt for any play in the bearing and also check that the disc shield is secure and not rusted at the fixing points an come adrift. Also you could try swapping the disc and pads from side to sidejist make sure the pads go in the same way as the other side to eliminate brake squeal.
  9. CheekyAudi
    13
    I`m going to investigate the problem sometime tomorrow , thanks for the pointers on where to look.
    I`ll post back if I`m successful in locating the rattle (wow its pissing me off now haha) or still left scratching my head
    Ta
  10. Bradderz_1988
    3,951
    235
    There annoying Aren't they I have 3 on mine 1. is the rattle from the wastegate 2. Is the 'D' pillar trim on the n/s/r the clips won't hold of there broken and 3. This one f***s me right off, it's from the dash and can't find wear it's from. I'm sure you will sort it !
  11. CheekyAudi
    13
    Well I've just dismantled the car and it's lying in bits just now ,
    The rear o/s spring is broken so I'll replace that tomorrow and the calliper on the other side is sticking so I'll free that up and do the pads also as there maybe 70% worn
    Not convinced thats what was making the metallic pinging noise but will report back once those jobs are done , and wether it's cured the annoyance
    Bloody cars lol
    Ta
  12. Bradderz_1988
    3,951
    235
    More than likely will be the spring TBH mate.
  13. aragorn
    18,306
    806
    Bradders: If the dash noise is around the knee bolster area, theres a flat metal clip thing that slides over a flat bit of plastic that sticks out, on the left side of the knee bolster.
    If your not careful at aligning the clip when refitting the bolster, it misses the flat bit of plastic and rattles/jangles around.
    Took me ages to work out what it was on mine!
  14. Bradderz_1988
    3,951
    235
    aragorn: never thought as when ive had it off and when refitting ive always put it on from the drivers side first and then realised that b*****d clip lol. will have a look tomorrow cheers mate you never fail to impress me with your knowledge what would we do without you lol
  15. CheekyAudi
    13
    Problem solved , it was the broken rear spring
    Easy enough fix
    Ta for the pointers
