Rattle from lower driver's side door
selar Apr 9, 2013
  1. selar
    selar Member
    161
    22
    So my week-old A3 has developed a rattle :( As soon as I reach 2100 - 2200 rpm I hit the resonant frequency of something in the lower half of the driver's side door. It sounds like a pen's sitting in the storage compartment but it's completely empty. I've got it booked in at Glasgow Audi for Tuesday morning.
    I don't expect anyone to be able to help - just wanted to share my (slight!) misery at having to be parted from it so soon!
  2. XXXCorps
    XXXCorps Member
    194
    27
    The A1 I used to have had a rattle upon collection from the inside door handle. When I took it out to demonstrate this, the tech was looking all over the interior asking where I'd hidden the sunglasses!! In the event the entire door handle and fittings needed to be replaced so know what you're going through...
    Ishj likes this.
  3. selar
    selar Member
    161
    22
    Hmm. I got the extended mono.pur interior so I hope that won't hold things right up...
  4. hittchy
    hittchy Active Member
    557
    74
    Normally their first course of action is to smother everything in anti-rattle foam and tape. There are unlikely to be any TSBs for rattles yet, so I think it'll be a bit of trial an error unless there's a fault screaming out at them.
    Have you got anyone pretty good at isolating where it comes from? If so, take them out for a spin so you can direct the technician to the exact location. You'll have far more chance of them solving it first time then.
  5. Vertigo1
    Vertigo1 Well-Known Member
    3,609
    705
    At least with Audi they don't quibble at all and understand that rattles and noises are unacceptable. On one of my previous A3s I had an annoying rattle from the central console somewhere so they dismantled the entire dash and put it all back together again to fix it.
    XXXCorps likes this.
  6. hittchy
    557
    74
    True, but some technicians are better with rattles than others. I'd be really worried about them stripping the whole dash out!
    They took the top part of the dash off my A4 because a TSB said the rattle would be there. It came back and did the same within weeks. Turned out it was the OBD port rattling. I gave up taking it back again and stuck some cardboard and insulating tape over it! Hasn't rattled since.
    I wish I'd listened to my own advice and discovered the exact location before taking it in. Rattles are notoriously difficult to pinpoint for techies unless they're loud and clear.
  7. selar
    selar Member
    161
    22
    TSB?
  8. Sootchucker
    Sootchucker Member
    101
    9
    Technical service bulletin
  9. hittchy
    557
    74
    Sorry.
    As sootchucker said above.
  10. selar
    selar Member
    161
    22
    Ah :) it seems to be from the lower trim around the B&O speaker. There's a bit of give in the plastic / rubber border and the noise changes tone when I put my finger on it. Thanks for the advice!
  11. Jax
    Jax Member
    23
    Developed one too. Three week old... Thousand mile in. Also seems really hard on suspension all of a sudden. Hoping just needing a bit wind in tyres :(
  12. jassyo06
    jassyo06 Voodoo Man ! Gold Supporter Team Sepang Audi S3 Black Edition
    11,026
    23,664
    My driver's door has something loose inside,it rattles constantly on any type of road surface, barring smooth motorway,its doing my head in, the passengers side, l have a high pitched buzzing noise resonating from the door,but its going in next week.....to get the door cards prised open,seen that done by a window tint company,not a pretty site.
    Rather annoyed,would rather it be mechanical problem, than the car's interior
  13. Don76
    Don76 Well-Known Member
    598
    322
    I have the exact same problem as described by the OP. Only it's the passenger door and between 1800-2000 RPM.
  14. Symon
    Symon Active Member
    136
    43
    My old ford had THE WORST rattle ever. It was an '08 plate focus. The passenger seat rattled loudly. When I put my hand on it & applied some pressure it would stop so when I had passengers they never got to hear it. Basically I took it to Ford who said it was an issue with the seat rail not the seat.
    Their expert assessment was that it couldn't be fixed. When I told them it was unacceptable on a new vehicle they said: " it's a ford mate, not a rolls Royce".
    It never got fixed.
  15. bexman
    bexman New Member
    17
    Did you get this fixed afterwards? I've got a similar issue with a new A3
  16. jassyo06
    11,026
    23,664
    I have this aswell since day one but not had the time to get it looked at by Audi but they can look at the rusty rear wheel hubs at the same time when l get the chance
  17. froggy
    froggy Member
    45
    15
    I think I must have the most bizarre door rattle ever.3 door s3 with B&O,every 2 to 3 week bad rattle mid door,lasts 30 mins then dissappears!
  18. jbs2472
    jbs2472 Active Member
    380
    55
    I have had the same rattle since new but only happens in really cold temps,I originally thought it was in the door and even said to Audi that it sounded like a pen rattling around. I recorded the noise in the end over a daily period and emailed this to Audi, the car has been in and out of Audi and they have now replaced all the area underneath the steering column and will not know if it has worked until we have sub zero temps.
  19. Rob2k68
    Rob2k68 Well-Known Member Team Daytona VCDS Map User Audi S3 quattro DSG
    6,908
    10,350
    Coming from a Leon the SEAT forum is literally plastered with posts on rattles so rest assured that the ones on here are few and far between and that Audi seem to be pro-active about getting them sorted out. On the Leon the fix was anti-rattle pads on the A pillar trims and a new design door trim pads - I'm not aware of any service bulletins for the 8V to correct rattles so I guess each one will be dealt with on a case by case basis.
  20. bexman
    bexman New Member
    17
    Just in case anybody is still interested in this. The annoying rattle was coming from the passenger seat height adjustment lever. Audi are replacing the whole height adjustment mech as there was too much play in it!
  21. Rob2k68
    6,908
    10,350
    Thanks for posting the source of the rattle. Sounds like an easy fix and no need to pull the door apart - result !!
  22. cam87
    cam87 Member
    192
    14
    just to add to this i had the passenger height adjuster adjusted on mine a few weeks back
