Rattle at top of door
ajmackie Oct 3, 2004
  1. ajmackie
    ajmackie Member
    922
    My A4 has an annoying rattle at the top of the door. I've read that it is a fault with the door not meeting the seal sufficiently. If I pull the door in at the top of the frame then it stops and starts again after a few bumps.
    Is there any permanent fix for this? /ubbthreads/images/graemlins/confused.gif
  2. imported_Yaseen
    imported_Yaseen Guest
    When you say rattling, do you mean the wind noise issue? If so there is an article in AW tech which may help.
  3. ajmackie
    ajmackie Member
    922
    Errrm. I think it is more of a rattle.
    I've checked that thing out, it is how to combat wind noise on the mirrors. Hmmmm, might get a hammer out!!!!
  4. imported_ZeroK66
    imported_ZeroK66 Guest
    could be the fuse box cover. Mine rattles... annoying as, next time you hear it, stick your finger between the door and the dash and see if holding the fuse cover makes any difference, just an idea (I know you said top of door)
  5. ajmackie
    ajmackie Member
    922
    yeah it is defo the top of the door.
    i heard that the door frame is seperate to the rest of the door and wondered whether it can be readjusted to fit tighter?
