random misfire/judder
jay1601 Dec 22, 2012
  1. jay1601
    jay1601 Well-Known Member
    1,311
    57
    car has started to play up over the last 2 days
    it will randomly judder. feels like a light misfire. when i come onto boost it will judder then after about 4/5 seconds it will be fine. no fault codes/EML
    going to start with replacing the plugs (done about 12K on current plugs bosch super 4's)
    engine: AGU
    with it being xmas haven't got a massive amount of spare cash at the moment. so don't want to go replacing random bits for the sake of it.
    been looking around online seems like the ignition amplifier seems like this comes up alot when searching for misfires on the 1.8T lump. would this be a good place to start after plugs ?
  2. jay1601
    1,311
    57
    stuck new plugs in made no difference.
    tested the ignition amp using this guide
    AudiWorld Tech Articles
    got around 200 ohms on all 4. so doesn't look like its that.
    coils ?
  3. Gops
    3,197
    666
    Coilpacks are the most common issue if a misfire on the engines. Coilpacks can be tempremental so advice is to change them.
  4. Oke Phill
    Oke Phill Member
    152
    +1 for sure!
  5. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Agree with coilpacks, you did not use Super 4s again did you? NGK all the way! I melted a set of super 4s and Badger5 say they don't get on well with those plugs too.
  6. turnstyle
    turnstyle Member
    91
    With misfire issues start with coilpacks
    if they are fine (tested by swapping them around to see if the misfire changes cylinder), then check spark plugs and the coil pack loom.
    If its spark plugs they will be coaked up with black soot or have evidence of arcing between points. Dirty brown colour is fine and normal.
    Loom is easy - if you have splits and can see exposed wire its either knackered or will be giving you more issues soon. You'll need to keep tracing back along the loom until the splits stop, and then solder a replacement loom in. Sounds scarey but its easy if you take your time.
    If all above is fine check vacuum lines - youll hear a hissing noice while engine is running. Thats a vacuum leak.
    Check boost pipes
    If its none of them and vagcom isnt helping the you'll need to check your compression.
    It going to be either be piston rings (blue smoke from exhaust?) or head gasket (white smoke from exhaust, mayo like substance on oil filler cap/dipstick, coolant level going down).
    A compression test will help you here (search youtube) and a sniff test on expansion tank for head gasket (goto a garage)
    Following that above should help you solve an misfire issue.
