Random locking/unlocking
AudiLeon Jan 5, 2014
  1. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    I think this is the CCM playing up.
    But when I unlock the car. It carries on unlocking then the windows go down abit. Then eventually all the way. When you're driving along, they keep unlocking and the interior light comes on. The dash doesn't suggest a door is open.
    It's a 52plate 1.9tdi AWX
  2. AudiLeon
    2,250
    192
    Well I replaced the CCM and it's still doing it. Hmmmm
  3. wesmaster
    wesmaster Member
    300
    20
    Have you tried using a different key/remote? could be drivers door lock or wiring in door shut. Just an idea
  4. quattrojames
    14,060
    583
    Have you been able to VCDS it at all?
  5. AudiLeon
    2,250
    192
    Yeh I have James, it's showing unable to de-safe rear. Which I don't think is the cause tbh.
    We only have one key sadly. I'm going to strip out the doors this week and look. It's just clicked onto 199k so there's a good chance.
    I've read online the door lock on the drivers door may be sticking and thinking the key is in the unlock posistion and causing the windows to go down. But I have comfort disabled. But does that disable the key in the lock comfort options??
    Lots of questions! First thing is to get the door wiring out, check for damage. Then check the circuit in the door lock for dry joints.
  6. lynall
    lynall New Member
    12
    Just had the wifes b7 drivers door apart trying to find intermittent door lock not locking, found slightly corroded pins in the door to a pillar plug, cleaned up and applied contact spray, its now working but for how long I dont know!
    Plug was held together with a cable tie so its been a problem before.
  7. AudiLeon
    2,250
    192
    I'll coat the pins in vaseline.
  8. AudiLeon
    2,250
    192
    Had it in lots of bits yesterday.
    Blanked the EGR, Fixed the rear wiper and 'hopefully' fixed the unlocking. Took the door locking mech apart and it had moisture in it. Stripped it all down, dried it out and sorted the seals out.
  9. H-M3
    H-M3 Member
    30
    Hi my bloody car does the same. Did you solve the lock problem? If so did you take any pics as I might attempt this....
  10. AudiLeon
    2,250
    192
    Hi H-M3,
    It did fix it. It was moisture in the drivers door lock. I didn't take photos I'm affraid. It's an easy but time filled job. You need to remove the door frame to get the lock out. After that, it's nice and easy to strip down. Take photos of the springs, so you know how they go back together.
