Rain sensitive wipers
46TheDoctor Mar 25, 2007
  1. 46TheDoctor
    46TheDoctor Valentino Rossi A.K.A The Doctor
    312
    :p Hi, any of you V dUB guys know how to disable rain sensitive wipers on my wifes 52plate bora tdi 130 sport, also when disabled does the variable intermittent switch still work?:jump:
  2. DaveP
    DaveP Member
    43
    When the variable intermittent switch is set to lowest that turns on the auto wipers, setting it to anything else makes them manual - I thought.
  3. 46TheDoctor
    312
    Cool thanks, ill give a go.:cool:
  4. vw754
    vw754 vorsprung Durch Technik
    2,325
    58
    SENSOR IS ON REAR VIEW MIRROR,YOU CAN SEE THIS FROM OUTSIDE,THE WIRING IS ON THE REAR VIEW MIRROR ASWELL
  5. Teutonic_Tamer
    Teutonic_Tamer GreasedMonkey HoofHearted
    122
    Main stealer, or VAG-COM
    Dunno, but I would have thought so!
  6. Stan 24v
    Stan 24v Member
    124
    Why you getting rid? Is it cos theyve got a mind of their own? Mine have!! :lmfao:
  7. 46TheDoctor
    312
    To be fair stan generally i think there quite good, albeit still a little too sensitive on the minimum setting, due to them being a little sensitive they tend to wipe the screen when its not really wet enough, thus my screen has really fine scratches in the sweep area and this must be caused when wipers are dragged across a dusty screen rather than gliding over a wet screen, the car has only covered 30k and screen is scratched to hell, whereas my audi has done nearly 70k, still on original screen with no scratches in sight and this car has regular manually operated wipers.:eyebrows:
  8. Stan 24v
    Stan 24v Member
    124
    Maybe the sinsitivity can be turned down?? May be worth a post on the mkiv forum mate.
  9. KarenCaren
    KarenCaren Member
    40
    Is there a switch behind the rear view mirror that can make it slow down like a switch on a christmas lights? If yes it would be easy.
    _________________
    Nice Find: Cargo Liners
