Radio reception problems after RNS-E retrofit.
nectop Apr 19, 2010
  1. nectop
    nectop New Member
    25
    Hello to everyone.
    I have Audi A4 B7 MY2008.
    My head unit from the stock was Audi Conecrt II+ I have swapped it to Audi RNS-E, I have bought used RNS-E and it's old one. (192C)
    I have very poor reception and an error in VAG-Com:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    I have read about different antenna system in Conecrt and RNS-E but I can't seem to fix it, because I have amplifier 8E5035225AF and rear screen with 4 connectors, and there is no such amplifier for RNS-E for my car. Or I should just buy a newer RNS-E unit, for example with 192T?
    Just in case my VIN is WAUZZZ8E98A014287
    Thank you.
  2. blackpool1974
    blackpool1974 Member VCDS Map User
    138
    Age of RNS-E will make no difference to your problem, they are all the same
    Some cars have 2x HF connectors in their antenna amps, the RNS-E uses 1x HF 1x ZF.
    Most people cope with just using the HF, the ZF doesn't make that much of a difference
  3. nectop
    nectop New Member
    25
    So there is only thing I can do, is to swap amp and rear screen?
    Witch do I need? Could you guys point me the part numbers?
    Thanks.
  4. blackpool1974
    138
    That seems a bit drastic changing the rear screen, there are a couple of audio experts on these forums, try and start a thread in the audio section or try using the search button
    In reality the RNS-E needs the same amp as every other radio, one with HF. The ZF is just a bonus if you have the option on your current amp
  5. auroan
    auroan Active Member
    1,669
  6. nectop
    nectop New Member
    25
    Which screen do I need and amp for sure?
  7. NHN
    29,505
    1,763
    I have PM'd JohnS3 who has experience on this more than myself, maybe he can advise your best route, but from what has been said & my knowledge, only way to get the best signal quality would be the amp/cabling/possible screen change.
    You would be best to ask someone who has the same car & an RNS-E from factory, for there vin number so you can check with ETKA which amps they have installed & the screen part number mate as there are several in ETKA.
  8. nectop
    nectop New Member
    25
    I have a few VIN's from the cars who has RNS-E from the stock.
    And they have totally different parts.
    Some has same AMP but other screen.
    I have amp with 4 connectors to the screen and I haven't found other screen then mine for it. So I probably need 6 connector screen and amp.
    Anyone can confirm it?
  9. JohnS3
    JohnS3 Active Member
    3,032
    We have covered a lot of this over on Navplus.us in this thread.
    http://audiforum.us/cables-adapters...-symphony-ii-antenna-system-use-rns-e-18.html
    As it appears that no one has done an A4 saloon conversion before (or not shared the information) so Nectop is going to have to be the test pilot. Being the first will usually cost you many late nights, money and you also end up with quite a large spares collection. But you didn't need me to tell you that Mr N!! ;))
    I wish Nectop well in his project and hope he does choose to share any information he discovers.
  10. NHN
    29,505
    1,763
    LMFAO, not wrong there mate, getting rid of the spares is the hardest part lol, but slowly going, then I think of something else or buy another car to mod, but better than pissing it down the drain or smoking myself to death I guess, got an SB to work on for missus, fancy doing an 09 facelift to that tbh.
  11. nectop
    nectop New Member
    25
    Oh John.
    I was afraid you will tell this.
    Heh. I have already bought wrong amp with letter 8E5 035 225 P it has 6 connectors to rear screen.
    Now I need to buy a new rear screen. But our local Audi Dialers are so dump.. they don't want to help and, what a shame, there is no cars with factory RNS-E in Russia, because there is no Russia Maps for RNS-E. Anyway, I have information that I need never RNS-E, and it will work.
    Yesterday I have tried to check voltage on both coaxial cables that goes to antenna amps, and only one has 12V on it, the second don't ... Also, I have found that it looks like there is 4 antennas soldered on the rear screen but I seem to can't find any amp other's then mine that has 4 connectors.
    So the question is, does both cables have to be with 12V? And what are the difference between RNS-E hardware revisions?
  12. dark_adi
    dark_adi New Member
    Hi, what voltage did you have on the second coaxial cable?
