Radio Reception Gone S***
Kyle. May 17, 2013
  1. Kyle.
    Kyle. Member
    70
    Recently then reception on my radio has gone terrible, before it was OK but has gone worse and worse. I've taken the cover off and played with the ariel, but just seems the same.
    The only time its worked properly was when I wedged a paper clip on it when it playerd up last year!
    Any ideas how to cure this??
  2. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Check where the cable goes across the boot lid ?
  3. Kyle.
    Kyle. Member
    70
    Where about is it?
  4. Cabbyfan
    840
    34
    In one of the rubber gaiters....the cable is prone to breaking on some models.
  5. Kyle.
    Kyle. Member
    70
    Where abouts are the rubber gaiters in the boot?
  6. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Open the boot and you'll see them near the hinges.
  7. Kyle.
    Kyle. Member
    70
    Seems like the wires are fine, any other ideas??
  8. NHN
    29,417
    1,740
    It may not be visible to the eye without pulling things apart more, I have fixed this various times on cabs with new cables, whats your location?
  9. Kyle.
    Kyle. Member
    70
    I'm in Cheshire, I've got a saloon though, that make much difference?
  10. NHN
    29,417
    1,740
    Ah sorry I quickly saw the A4 Cab in the forum title & made an assumption mistakenly, well there's an amp above the rear window iirc, this maybe at fault, ideally testing with another radio would be good, is it a single or double din unit?
    PM me if you want it looked at.
  11. Kyle.
    Kyle. Member
    70
    Its an rnsd, it works fine of I push on one side of that amp?
  12. NHN
    29,417
    1,740
    Remove amp & check all connections to & the pcb itself for damage, but I seem to recall some amps just going faulty, what's the antenna amp pat number?
