radio question
rob v6 Feb 26, 2010
  1. rob v6
    rob v6 Learning the VAG way
    161
    Just wondering will a symphony 2 with built in 6 cd changer fit in a a4 b5 that has a symphony radio already fitted?
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,893
    724
    I take it your talking about the B6/B7 symphony unit, if so then you would need a can-bus converter (if your car does not have infotainment can-bus, at the instrument cluster) there would also be gaps around the centre console.
    Also the rear speaker would need to be driven by an amp, if they are not already.
  3. rob v6
    161
    ok thanks mate so it would work with a bit of work
  4. B5NUT
    3,893
    724
    Yes, with a bit of work. I fitted RNS-E into a single DIN B5, so anything is possible. What MY is your B5?
