Radio issues!!
simers Dec 15, 2013
  1. simers
    simers Member
    140
    21
    In my B6 A4 since I've had her I can't get any radio stations in her.. I no nothing about electrics so I need help as to what it could be?? Anyone any ideas??
    Simon
  2. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,722
    162
    We need a bit more info....
    What headunit do you have? Genuine or aftermarket?
    The aerial is in the side rear window if its an Avant. Not sure where it is located on the saloon models.
    Dan
  3. kite
    kite Member VCDS Map User
    677
    The antenna amp is above the rear window in a saloon and known to fail. Not cheap to replace....
  4. simers
    simers Member
    140
    21
    She's a saloon with genuine head unit.. Anyone have a spare antenna amp?? If so how much to Ireland delivered??
  5. S4_dan
    2,722
    162
    Before buying an antenna amp, why not remove the headunit and check the aerial connections and check the wiring/aerial to see if all is good.
  6. simers
    simers Member
    140
    21
    She picks up some channels but reception does be rubbish.. I'll pull it out in the next day or 2 when I'm mobile again...
  7. kite
    677
    The amps are not cheap. I would not buy a second hand one as so many fail. As Dan says check all wiring first.
  8. simers
    simers Member
    140
    21
    Cheers guys... Ill post results when I can walk again properly..
