Radiator staying on when all turned off?
A3Kent Oct 24, 2012
  1. A3Kent
    A3Kent Well-Known Member Team Daytona Audi A3 S-line owners group TDi
    1,570
    249
    Hi guys
    Any reason why every so often my A3 2.0 TDI 170's front radiator is staying on for about 5 minutes after i've turned the engine off etc? It's done it twice now and happened tonight after returning home on my usual 13 mile journey home from work, I wasn't exaclty thrashing it either.
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    DPF regen interrupted I'd say.
  3. mjr901
    mjr901 Guest Gold Supporter Audi S3
    3,595
    1,063
    you mean the fan.....?
  4. A3Kent
    1,570
    249
    The fan on the radiator then...
  5. NHN
    29,329
    1,708
    Do you run aircon all the time or just occasionally & was aircon on at these times.
  6. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    Have a read of this thread:
    possible radiator fan problem
    It's a common problem on A3s.
    Please have a look at the FAQs thread too, that's where this link came from.
  7. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,663
    116
    Fairly common fault.
    Open the bonnet with the engine running an AC off and watch the fans. Only the large radiator fan on the right should be moving.
    Now turn on the AC, wait a few minutes and keep watching the fans. If the smaller fan still doesnt move and the large radiator speeds up and sounds like an aeroplane taking off.. The fault is with the smaller fan.. £150 for fan + labour.
  8. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,281
    288
    Or the DPF re-gen has been interrupted as A6CR says. I get this on the A4 from time to time, usually with a slight smell of burning (I'm assuming from the increased tempteratures needed for re-gen)...
  9. A3Kent
    1,570
    249
    Always stays on mate.
    I'll try this out.
    This is helpful too -
    http://www.audi-sport.net/vb/air-conditioning/57270-air-con-climate-control-faqs.html
    It's possible that's it's normal behaviour as my air con is always on.
    I'll do some tests and report back.
    Thanks chaps.
  10. A3Kent
    1,570
    249
    I should also mention that the car was checked for error codes via VCDS only last Sunday and no errors were present....
  11. audicruiser
    audicruiser Audi Heaven
    1,865
    Sounds like the common fan problem as this shows no errors. Get it sorted though as you'll come back to a flat battery!
  12. A3Kent
    1,570
    249
    its only done it twice in about a month though, both times it's gone out in about 5 minutes. Surely that won't flatten the battery?
  13. eric barrington
    eric barrington New Member
    hi
    try the temp 3 pin switch situated screwed in the radiator, this keeps the fans working after the engine in switched off and works on a temp in the radiator, cheap to change, also is the engine temp normal if is reading high the fan will run on after switching off
