Radiator fan staying on
AshA4 Nov 10, 2012
  1. AshA4
    AshA4 Ash
    285
    Hey guys quick Q?
    Just been out for a short drive, didn't tank it took it nice and steady (ave 42mpg) pulled car onto drive and turned her off.
    Noticed the radiator fan stayed on, temp gauge in car was just below half way and it is 7.5 deg outside temp.
    Fan stayed on for about 5 mins, I am guessing this is normal but I have not noticed it on my car before?
    Would expect this during high summer temps but not in winter?
    I did search but found nowt :)
  2. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,805
    616
    I can't see your sig because I'm on my phone but I'm assuming you have a diesel... As far as I can make out that's a DPF regen interrupted as mine does this as well (3.0 TDi). Nothing to worry about I'd say mate. :)
  3. AshA4
    AshA4 Ash
    285
    Yes mate 2.0tdi :)
    What is a DPF Regen?
  4. Daggerit
    1,805
    616
    The diesel particulate filter (DPF) gets clogged up with the soot it's stopping coming out the exhaust pipe and so the regeneration cycle cleans it out by burning them off. If your normal driving doesn't do it, normally by higher revs for a decent amount of time like on a motorway, then the car will automatically adjust the fuelling to create higher temperature exhaust gasses and carry out regen 'manually'. It still continues after the car is off as far as I know.
    What exactly the fan does for this once you turn the car off I don't know but it seems to continue fuelling so maybe it's to keep it cool or something? I also notice a slight burning smell at the same time...
    AshA4 likes this.
  5. AshA4
    AshA4 Ash
    285
    Cheers mate, knew what the DPF was but now know a lot more.
    Makes sense too as I did baby the car on that run, thanks again :)
  6. @ndr3w
    @ndr3w Member
    60
    Is the burning smell like burning rubber? if so, mine does that!
  7. Daggerit
    1,805
    616
    Yeah a little bit actually! :)
  8. a4sline
    a4sline Member
    185
    Another DPF giveaway is, was the car running at about 1000rpm at idle before switching off ?
    If so was in regeneration, along with fans and burning smell, probably regen.
  9. @ndr3w
    @ndr3w Member
    60
    Thank God for that!
    It happened the other day and the missus said I must have been going round corners too fast! Cheek! :)
  10. Daggerit
    1,805
    616
    Funnily enough mine did this again when I got home and it definitely smells like burning! Haha.
  11. Tan A3
    Tan A3 New Member
    Help!!! Audi a3 2.0 tdi
    My Audi A3 has a few faults and im trying to work out if its worth keeping or get rid??
    1. The fan keeps kicking in and seems to be getting worse, not overheating temp stays at 90.
    2. Diagnostics says theres 7 faults, [​IMG]
    3. Loud whistle when driving, especially when giving the boot! not modified!!
    4. New sound now when boot is applied, and losing power....
    PLEASE HELP, thanks, [​IMG]
