RAC fault code / diagnostic scanner
aythree May 17, 2009
  1. aythree
    aythree Guest
  2. mhill
    mhill Member
    323
  3. martyboy
    martyboy Member
    532
    20
    slightly cheaper than vag-com!!! :)
  4. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    if you get one from argos and it doesnt work or is as good as expected, you can return it.
    just make sure it does can bus on 2004+ audis etc. and your in business.
    and you get a year guarantee.
    my local garage uses one and it was pretty good until i got my vag com.
  5. aythree
    aythree Guest
  6. heliflyer
    heliflyer Member
    149
    Hi mate sounds like you have just answered your own question ,argos rac e bay all made in china goto be worth paying the extra for vdcs plus you will always be able to get help from ross tech and this forum argos couldnt give me the answeresd that members on here have cheers Ian
  7. aythree
    aythree Guest
    Wouldn't have put the RAC ones in the same bracket as the ebay ones.
    Might give the RAC one a go and return for a refund if necessary. Nothing to lose there really.
    Ross-tech is just too expensive for my needs. I really only want to be able to scan for errors and clear if needed, that's about it. No re-coding etc etc.
  8. mhill
    mhill Member
    323
    It works just fine no agro just plug & play, I ordered it around 20:00 on a Friday evening and it was here on the Monday by mid day courtsey of TNT express. When it turned up the driver disc was cracked contacted the support and I had it downloaded from their web site and running in a hour!
  9. aythree
    aythree Guest
    Ok, I see it's $30 for the cable and software, how much is the shipping?
    Also, what is the software they use?
  10. mhill
    mhill Member
    323
    If you look on the website for the postage, it's a little high but it's seriously quick. It uses Vag Com 805.0
