R32 Gearbox - Will it fit?
Stewart Jan 16, 2007
  1. Stewart
    Stewart Member
    705
    10
    Does anyone know whether the R32 Gearbox will fit the S3? Same ratios? Or similar?
    I'm fed up with the notchy gearchange.
  2. Ess_Three
    Ess_Three Active Member
    5,383
    Physically the same size as the S3 'box...but the bellhousing bolts are incorrect.
    The S3 engine leans back towards the bulkhead in relation to the gearbox, the R32 slopes forward in relation to the gearbox...
    Same as the old 2.0 16v O2A gearboxes vs the VR6 O2A gearboxes...
    Are the ratios any different?
    I'd have thought a petrol 'O2M' would likely be the same for S3 and V(R)6 in terms of ratios?
  3. Stewart
    Stewart Member
    705
    10
    Ok, thanks Glen.
    If my gearbox ever gives up the ghost completely, it might be worth spending the time swapping the internals maybe...
  4. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    There has to be someone that's going to do the 3.2 DSG conversion. If you could stop buying wheels, you should put some money into that ;)
  5. madvw
    madvw Active Member
    2,489
    The ratio's on my corrado VR6 were loads different to a G60. The VR6 had long lazy gears that used the torque whereas the g60 had punchy closer ratio gears (or so it felt anyway).
    No idea if this translates into their modern equivalents though.
  6. Stewart
    Stewart Member
    705
    10
    LOL !
    Why would I want to put a heavy lump like that into the already lardy S3?
    Had to spend money to reduce the understeer and all that weight at the front would bring it all back :(
    Admittedly it would be a dream to drive...
