R-tech stage 2 remap
stevegti2 Feb 26, 2013
  1. stevegti2
    stevegti2 Member
    229
    13
    hi quick question if anyone knows i want to book my car into r tech for a stage 2 remap and was wondering if i need injectros or a 4 bar fpr
    my car is a A3 aum 1.8t
    mods are
    turbo back exhuast
    silicone tip
    ebay recirc dump vave
    cold air intake
    Fmic
    i have a s3 m.a.f housing wich i can fit if its needed aswell just wondered about fueling as thats the last thing i would need to buy before i can book it in
    thanks steve
  2. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,130
    356
    Cant help you there steve, when you going? Im booked in for next month...
    If i remember Prawn said your standard injectors are larger than agu ones. Yours can handle the stage 2 where as my injectors would max out earlier??
  3. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    if you still on k03s turbo then you dont need a s3 maf or injectors.....
  4. Prawn
    11,676
    3,673
    As marty said, on an AUM you don't ever need a maf or injectors with the stock ko3s, mylo took his all the way to 264bhp on standard items, and that's never going to be beaten I don't think!
  5. Paradox1
    1,833
    88
    264 fro a k03s?????
    makes me think why bother going k03s hybrid lol
  6. Prawn
    11,676
    3,673
    Yes, 264.7 on the Badger5 dyno.
    Reason to go for a hybrid, is that you will never ever come close to equaling that figure Marty, I doubt anyone will, it was a mutant!
  7. stevegti2
    stevegti2 Member
    229
    13
    my m.a.f is not standard it is a bosch but its new as in not original it was from euro car parts as far as im aware its same as one i removed even though one that was on there was not original i gave them reg when ordering.
    so technically my car is ready for a remap....
    i rang r-tech today but no answer il try again tomorrow
    thanks for info
    prawn wasnt that 264 with wmi.....
  8. badger5
    9,603
    2,061
    LOL & feck me... how many times is mylo's mutant going to be named as what a k03s will do?
    Normal K03s WONT....
    It was not std K03s.. It had 12psi actuator on it, and ran 80% Methanol injection to achieve its "impressive" figures
    If you think you can drive in with an aum on stock k03s for a custom stage 2 map and drive out with 263bhp you will be most dissappointed.
    Mylo's unaided airflows from the K03s airflow was 245bhp for of air.. Very very impressive for a k03s, BUT, the rest came from timing allowed by running 80% methanol in its wmi injection. The stiffer actuator helped it hold mid range boost superbly, way more than a std k03s, BUT its not std actuator..
  9. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    Pretty sure it was 80% meth, 20 % water.
    EDIT: As Bill has stated in more words above.
  10. badger5
    9,603
    2,061
    comparison of a std k03s boost delivery and what can be held with mylos 12psi one, and lots of wmi meth timing
    mylos monstor in red btw, looks how well it holds boost with the stronger actuator.. superb!
  11. Jason.s
    Jason.s Active Member
    2,879
    348
    Oh and while the subject is flying around everywhere at the minute i`d probably swap out the ebay dv for a new OEM unit or atleast a 007p with latest service kit.
  12. Paradox1
    1,833
    88
    I got a Forge actuator on my k03s. Bill is this the same one that mylo was using?
    Im not too keen on running my k03s flat out although im sure it would be fine while it lasted.
    Bill - what would be sensible figures to run on a k03s with WMI added into the map?
  13. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    It was a K04001 actuator I think.
    250 with meth IMO, it's more about the torque in terms of safety.
  14. Paradox1
    1,833
    88
    sounds reasonable Jardo,
    Im just being a bit greedy as im more than happy with my k03s. i havent driven it for over a month so when i do finally get it back on the road, im sure it will go well. I have k04 mani and downpipe among other parts but thought i might as well make the most out of my current setup.
    Can someone tell me how long I would need to leave my car with R-tech/Badger 5 for them to map in the WMI??
  15. Jay A3
    2,130
    356
    I think Westy left his there for a week
  16. badger5
    9,603
    2,061
    no, his actuator was one of nikis i think off k04-001 12psi one.. 5psi std
    if you have forge you can change pressure with springs and preload to dial more in. do it wit spring more than winding up preload... you cannot take too much actual travel out og the actuator
    wmi depends on what % you want to run vs what the additional meth contribution for octane (allows more timing adv)
    mylos is the gauge for max, work bac from there to the polo ko3s comparison I posted, which was just my custom map for stage 2 mods.
  17. Paradox1
    1,833
    88
    OK thanks Bill, I usually run 50%water/meth or just deionised water and I always run over V-power. TBH I dont think I need a full custom map. maybe just a few tweeks. last time I was at Rtech, nick added TIV to my car so I guess the longest thing will be getting the full potention out of it. Im more than happy to leave my car with B5 or Rtech as I know its in good hands either way.
    Something I might consider in the a few months.... End Jardos K03s King Reign:racer:
  18. Prawn
    11,676
    3,673
    Sorry Bill, didn't mean to wind you up, I simply stated the figure as what was achieved with stock injectors and MAF, using it as a case to show that for any normal ko3s AUM injectors and MAF will not ever be needed. I did point out to Marty that the chances of replicating this figure were slim - none.
  19. badger5
    9,603
    2,061
    its hard to imagine the injectors not being max'd duty cycle tho. Must have been 4bar fpr maybe?
    I'll have to look at the polo's logs to remind myself what idc it did
  20. stevegti2
    stevegti2 Member
    229
    13
    so in answer to my question no i do not need injecors or a m.a.f
    thanks
  21. 16Klappe
    5,795
    1,187
    No! It has been said by everyone that they are fine, and if you needed them Niki would have told you to get them before you got to his.
  22. Jay A3
    2,130
    356
    With that all sorted now, time for you to get on the blower and get booked in mate!
  23. stevegti2
    stevegti2 Member
    229
    13
    indeed jay ill ring em next week
