R-Tech stage 2 plus. Is my car ready?
g60leigh Oct 25, 2013
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Will check the health of my current one and go from there I think. The classifieds one looks like a tfsi one but I could well be wrong mate.
    I'm still going to have a look into proven upgrades for the system on ours.
  2. Scullies
    Scullies Well-Known Member
    1,543
    658
    Depending on cash flow and time frame, I would fit a surge tank/swirl pot and get the da-31. That way there is not strain on the OEM pump as it just flows round in a continuous loop with no real pressure in the system. DA-31 will draw the fuel from the surge tank and be doing all the hard work.
    you basically need a aluminium or stainless steel container that will fit somewhere under the car. it needs 4 fittings on it.
    1 for the fuel supply from OEM tank pump
    1 for the return to the OEM tank
    1 for the return from the fuel rail
    and last one for the supply to da-31
    the first 3 fittings I would fit near to top of the container and the fitting for the supply to da-31, should be a little bit up from the bottom of the container.
    and don't forget a fuel filter between tank and inline pump. You don't want the new pump to get clogged or damaged by random bits.
  3. g60leigh
    1,674
    207
    What is the best option to go for on the fuel pump side.
    Which in tank pump and if I get a good one do I also need an inline one?
  4. Westy
    Westy Well-Known Member
    17,443
    1,105
    OEM in tank is fine for your power. If you want to go silly in the future you can then add an in line.
  5. g60leigh
    1,674
    207
    Forge actuator purchased.
    Bosch 550's ordered from US
    Fuel pump needs to be tested still.
    Also picked up a phenolic inlet manifold gasket too.
    Scullies likes this.
  6. Scullies
    1,543
    658
    Next on the list BBT Hybrid :)
  7. g60leigh
    1,674
    207
    Not quite. But one day possibly haha
  8. Scullies
    1,543
    658
    thats the spirit :)
  9. Dani_B19
    9,382
    403
    Hope youve ordered the 550's off a reputable company.
  10. g60leigh
    1,674
    207
    Got them from a classified add on a.n.other forum.
  11. Dani_B19
    9,382
    403
    Id get them checked. Few lads on thw vag FB pages bought 550's off ebay from across the pond and they turned out to not be 550's.
  12. g60leigh
    1,674
    207
    Yeah from econoline. They are off the smaller engine Shelby gt500
  13. g60leigh
    1,674
    207
    Just to be on the safe side. Is anyone able to confirm the part no's of the correct / compatible ones?
  14. g60leigh
    1,674
    207
    Bit of an update and delay
    Had new paddle clutch fitted along with a phenolic inlet gasket.
    Sourced some Bosch Motorsport 550cc injectors and a forge actuator.
    But.
    Signs of head gasket problem (caramac **** on oil cap) so bitten the billet and am getting a set of rifle drilled forged rods to have fitted at the same time.
    Still planning custom map on K04 turbo but will have to get rods in and run in first now.
    Jason.s likes this.
  15. g60leigh
    1,674
    207
    One question that's sprung to mind.
    The head gasket.
    Is it best to use oem gasket or is there an uprated option available?
  16. superkarl
    superkarl MAN OF STEEL
    9,610
    2,481
    Oem mate.
    The 1.8t headgaskets are bombproof
    g60leigh likes this.
  17. Sean_S3
    Sean_S3 Member
    323
    17
    Pretty uncommon for head gaskets to go on 1.8T's , mayo on oil cap could be down to the cold weather.
  18. superkarl
    9,610
    2,481
    i agree, condensation fooling people.
    Give it a long run where it gets nice and warm, mayo should dissapear.
    you'd also have mayo or contaminent in the coolant bottle if you had issues.
  19. g60leigh
    1,674
    207
    Done the long run and mayo lessens but is still there. Loosing a little water too. Only about 500ml a fortnight - three weeks.
    Rods ordered now anyway so head gasket is still good excuse to the wife lol.
    Hope head gasket is ok though so I can get Christmas out of the way before having it done.
    Going to try and get a chance to pressure test the cylinders this week.
  20. Sean_S3
    Sean_S3 Member
    323
    17
    Same thing happened to me recently , losing a little coolant and mayo on the oil cap and dip stick but no obvious leak so I feared the worst.
    Had a coolant pressure check done which highlighted a leak on a braided hose then a compression test done to put my mind at rest. The garage said HG is rare on our cars.
  21. Gops
    3,198
    666
    Yeah HG is rare.. Do you have a catch can? And does the water res have mayo?
  22. g60leigh
    1,674
    207
    Yeah I have catch can. Water reservoir bottle is fine.
  23. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    get a local MOT garage to Sniff the water bottle for HC takes 5 mins
  24. g60leigh
    1,674
    207
    Asking for help again lol.
    When I fit rods I will be fitting new con rod bearings.
    Am I best getting bearings at ends if crank shaft and oil seals changed too?
    If so please can anyone tell me what I need to buy. Part no's or links would be great.
  25. g60leigh
    1,674
    207
    Plans have changed.........
    Rods still getting done plus a little bit more now.
    Still could do with help on the above question.
  26. s3dave
    10,110
    736
    I have changed the seals but the bearings were super smooth so i left them, on the few builds that i have seen they have all been fine, but obv check...
  27. g60leigh
    1,674
    207
    I will get seals ready and have the others checked. Can anyone help me with a part no please.
  28. Gops
    3,198
    666
    It's mad how things change on a daily basis! Happens to me now!! Lol.. Change everything that you can mate.. It's better now then taking it all apart again..
  29. g60leigh
    1,674
    207
    The way things are going I may have to do a build thread. Haha
    StaceyS3, ScottD3 and Westy like this.
  30. chaz20vt
    chaz20vt Member
    428
    21
    ^^^^ sounds like a plan
  31. Scullies
    1,543
    658
    are you taking the box off? If so I would do all the main bearings as well as front and rear seals.
  32. superkarl
    9,610
    2,481
    I got my front and rear seals from ecp and gsf i think. Theyre a fortune from the dealer. I never changed main bearings because they looked perfect
  33. g60leigh
    1,674
    207
    You ain't got part no's floating around have you Karl?
  34. g60leigh
    1,674
    207
    With my broken glass back and op on the 19th I won't be doing any of the work. I don't think he will be taking box off tho.
  35. g60leigh
    1,674
    207
    I have today taken delivery of this:
    <a href="http://s103.photobucket.com/user/g60leigh/media/1D17698C-8D29-4E14-8560-10F8F217816F_zpszfpqow0u.jpg.html" target="_blank"><img src="http://i103.photobucket.com/albums/m141/g60leigh/1D17698C-8D29-4E14-8560-10F8F217816F_zpszfpqow0u.jpg" border="0" alt=" photo 1D17698C-8D29-4E14-8560-10F8F217816F_zpszfpqow0u.jpg"/></a>
    <a href="http://s103.photobucket.com/user/g60leigh/media/42DEEC75-20B8-4656-815D-0D355CFF1879_zpsu3ca0dlm.jpg.html" target="_blank"><img src="http://i103.photobucket.com/albums/m141/g60leigh/42DEEC75-20B8-4656-815D-0D355CFF1879_zpsu3ca0dlm.jpg" border="0" alt=" photo 42DEEC75-20B8-4656-815D-0D355CFF1879_zpsu3ca0dlm.jpg"/></a>
    <a href="http://s103.photobucket.com/user/g60leigh/media/0695F21C-54C7-408E-A083-E6F4CD852198_zpsravbzcqm.jpg.html" target="_blank"><img src="http://i103.photobucket.com/albums/m141/g60leigh/0695F21C-54C7-408E-A083-E6F4CD852198_zpsravbzcqm.jpg" border="0" alt=" photo 0695F21C-54C7-408E-A083-E6F4CD852198_zpsravbzcqm.jpg"/></a>
    <a href="http://s103.photobucket.com/user/g60leigh/media/6A4854E0-1A0B-4BE7-BDC5-566C390E1315_zpsjyplceqc.jpg.html" target="_blank"><img src="http://i103.photobucket.com/albums/m141/g60leigh/6A4854E0-1A0B-4BE7-BDC5-566C390E1315_zpsjyplceqc.jpg" border="0" alt=" photo 6A4854E0-1A0B-4BE7-BDC5-566C390E1315_zpsjyplceqc.jpg"/></a>
    http://www.turbodynamics.co.uk/shop...rbo-for-audi-s3-tt-and-leon-cupra-p-2728.html
    Since I'm doing the rods and planning a custom map. It seems it would be rude not to add a hybrid turbo. Especially when I stumbled upon one with really low and at a good price (I think).
    Opinions on wether I should fit at same time as getting the rods done or wait until rods have bedded in.
    I understand the best thing to do is fit and run on actuator pressure (n75 disconnected) should I use the forge actuator I have sat in the garage or stick with the one already on it.
  36. superkarl
    9,610
    2,481
    I can try and have a look, im not sure if i do have themWhen do you need them by?
  37. g60leigh
    1,674
    207
    Still waiting for my rods from ie so no panic. Just gonna order them up ready.
  38. Scullies
    1,543
    658
    FYI, rear main seal requires box and clutch to be taken off and front main seal requires removal of crank gear. Also doing main bearings with the crank in the block won't be an easy job. I remember Bill managed to do them on Stacey's build, without removing the crank.
  39. s3dave
    10,110
    736
    I should imagine his engine is coming out for a major build, madness trying to do all that in situ...
    put your new turbo on at the same time leigh, old injectors, n75 unplugged..
