R-Tech stage 2 plus. Is my car ready?
g60leigh Oct 25, 2013
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    Once I get my clutch replaced I'm looking for a custom map.
    Been in touch with r-tech and I think I'm close to the spec needed for the stage 2 plus.
    My two worry areas are.
    1 Bar plus actuator needed - I'm running standard K04 actuator which comfortably holds over one Barr. Is this sufficient? Or do I need one that holds 1 bar with n75 disconnected.
    Intercooler.
    I have a ah fabs v1 intercooler. If I upgrade the pipework to 2.5" will the core be up to the job?
    I'm aiming for 300bhp - turbo permitting.
    I have the WMI installed already and have Bosch 550's in their way over the pond to me.
    I'm hoping I'm close to spec needed.
    Westy likes this.
  2. <tuffty/>
    20,881
    3,701
    Bills lupo runs the V1 core with 63mm pipework at 300hp... be fine
    g60leigh likes this.
  3. g60leigh
    1,674
    207
    That would be great if it would. I have WMI set up too so should be extra help. Never (yet) had any heat problems.
  4. Westy
    Westy Well-Known Member
    17,443
    1,103
    Leigh what's your cara full spec? Similar to mine I think.
    Don't worry about the actuator too much as niki won't go above 21psi.
  5. g60leigh
    1,674
    207
    Forge FMDV008 Recirculation Dump Valve
    Revo Stage 2 ECU Map
    Badger 5 V2 TIP with J&R Cone filter and Heat Shield
    TFSI Coil packs with NGK Iridium Spark Plugs
    Evap removal
    Miltek Cat back stainless steel exhaust
    AH Fabrications V1 front mount intercooler
    Relentless V2 tubular steel manifold
    Relentless V3 3” Down pipe and 200 cell sports catalytic converter
    Oil catch can and PCV removal
    Titanium manifold heat shield
    AEM 30-3000 Progressive WMI
    Running standard K04 but seems strong
    Just had timing belt. Water pump. Oil pump and pick up changed on last service (2weeks ago)
    Stage 3 paddle clutch coming soon.
  6. g60leigh
    1,674
    207
    I'm gong off of the email I received from one of the guys at r-tech and that was on their requirement list for stage 2 plus.
  7. Gops
    3,197
    666
    If you want an actuator.. BBT is the man. I only popped one on because mine was fubard! But just turned out it made everything better lol! Have you got a manifold? My injectors maxed out at 280bhp!
  8. g60leigh
    1,674
    207
    Relentless v2 exhaust mani.
    Standard inlet.
    Bosch 550's on way ready. Still need adaptors though.
  9. Westy
    17,443
    1,103
    Same a mine Leigh except I have a decat. How's your fuel pump?
  10. g60leigh
    1,674
    207
    Fuel pump is fine as far as I know. Is there a way of testing?
  11. Westy
    17,443
    1,103
    You can put a gauge on the fuel line to check. My pump was brand new but that is one o the big mods that people don't realise.
    I'm excited to see what yours can do.
  12. g60leigh
    1,674
    207
    Will look into that. Thanks for the heads up. May hit eBay to price one up.
    I'm excited myself for this. I'm running stage two revo now with a few adjustments on the SPS switch. But never been one to chase rolling road figures. So don't truly know what I'm at now.
  13. g60leigh
    1,674
    207
    Do you know what pressure it should be running?
    Looking a fuel pressure gauges now lol.
  14. Westy
    17,443
    1,103
    I can't remember but bill posted on a thread in the last 2 weeks advising someone of the pressure.
  15. g60leigh
    1,674
    207
    Found it.
    It should be 3 Barr + boost pressure and rise with boost.
    Westy likes this.
  16. Scullies
    Scullies Well-Known Member
    1,543
    657
    Be worth checking for boost leaks before the remap, in case there is something that is not as simple as just tightening up the clamp.
  17. g60leigh
    1,674
    207
    Given it a thorough visual after getting it back from timing belt. And holding boost with no drop off.
    Unfortunately I don't have access to a smoke tester. Would love to test with one of them.
  18. Scullies
    1,543
    657
    I use a compressor hooked up to the TIP and squirt soapy water over joints and look out for bubbles. mcgyver mechanics 101 :)
    S3_, s3dave, Westy and 1 other person like this.
  19. g60leigh
    1,674
    207
    I've got a tester I can use similar to that. If I can adapt it to fit K04 tip.
  20. cecilthesausage
    cecilthesausage ...It's Never Finished...
    933
    112
    My pal has a smoke tester Leigh.... Manser motors over on the BonLea.... Behind the old Audi Garage...
  21. g60leigh
    1,674
    207
    You know how much he would charge to run a test Rob?
  22. superkarl
    superkarl MAN OF STEEL
    9,400
    2,376
    Id be inclined to get an uprated actuator from dan.
    Whilst it might not give bigger headline figures, not that youre chasing any, but power and torque will be sustained longer, that will be a big difference in performance from a car that hdas a weak stock one.
    Gops' results speak for themselves.
  23. g60leigh
    1,674
    207
    How much of a job is it to fit on the S3? Is it a turbo off job or can it be done in situ?
    Thanks for all the pointers guys.
  24. cecilthesausage
    933
    112
    I'm not sure.... Have a ride over and see him tell him I sent ye....
  25. g60leigh
    1,674
    207
    Lmao. Tell him Vinny sent ya.
    Got a few bits to change over first. Including the red turbo flexi ( thank you for that mate 😉 )
  26. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    20 mins max to change the actuator leigh..
    Charge pipe off, 2 nuts turbo side ...then the nut holding the rod on the wastegate, just may have to mess with the pre load to get it spot on (usually 3-4 turns from the wastegate been shut)
  27. g60leigh
    1,674
    207
    Cool
    Done in situ?
  28. s3dave
    10,110
    736
    yeah edited....above..
  29. g60leigh
    1,674
    207
    Sounds good. I like easy jobs.
    Westy likes this.
  30. g60leigh
    1,674
    207
    Messaged Dan to see what he says about actuator.
    Toying with idea of changing intercooler pipework still.
  31. Prawn
    11,408
    3,290
    I'd say an actuator is absolutely essential, for what it costs, and the figures you're hoping to get, it'd be madness not to do it given what we know now through the last 18 months of development.
    Also, if your fuel pump is original, it'll be highly likely to be a limiting factor IMO
  32. g60leigh
    1,674
    207
    I agree. The invaluable advice in here has put them firmly on my radar.
    Going to assess the fuel pressure with an inline gauge and then look at options for up rated fuel pump. I've seen a few options for FWD but not come across any for 4wd. Yet!
  33. Prawn
    11,408
    3,290
    Problem is, with a fuel pressure gauge, it'll only be measuring whether it's keeping up NOW won't it? Not whether it'll keep up when most is asked of it, if you see what I mean?
    Fred saw very decent figures from his ko4 with a stock actuator, but on the whole it seems that power and torque are far easier to sustain with a decent actuator fitted, like on Gops car, it seemed to be the key to a sound result.
    Very good cars will still make the figures without clearly, but better to be prepared I'd say.
    StaceyS3, Gops and Westy like this.
  34. g60leigh
    1,674
    207
    That's a very good point Mr Prawn.
    Fuel pump now added to the list. Any suggestions for updated options.
    Actuator will be changed. Just waiting for Dan to get back to me and one will be ordered.
  35. Scullies
    1,543
    657
    that DA-31 seems to be a popular choice for you guys on that side of the world.
  36. g60leigh
    1,674
    207
    Is that an in tank replacement. ?
    Will search it out when I'm at home.
  37. Westy
    17,443
    1,103
    No it's an inline one.
  38. g60leigh
    1,674
    207
    Will that be sufficient or do I need both upgrading?
    I really need to get chance to sit in front if computer and have a search. Can't find anything in tappatalk
  39. Westy
    17,443
    1,103
    You really need to have a healthy in tank pump. The pump will support the power you want. If you then want more power you can add an inline.
  40. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    195
    Just seem this is classifieds on here:
    http://www.audi-sport.net/vb/classifieds.php?do=viewitem&itemid=9155&urlid=2
    Might be if use.......... Someone in the know can tell you.
    Sean
